Old 07-12-2009, 05:41 PM   #1
San Diego , California
Question Best/quickest way to recharge batteries?
When dry camping, if we need to recharge our batteries, we have a Honda EU2000i. It has a DC charger cord that plugs into the control panel and has two clips that attach to + - (red/black) on the batteries. It says to run the Honda without the eco-throttle when charging batteries.
Would it be better to recharge them with the DC cord directly to the batteries or would it be better to plug the 30 amp 120v. power cord from the AS into the 120v outlet on the Honda and let it run in eco-throttle?
Thanks, Randy
OB Bambi is offline   Reply With Quote
Old 07-12-2009, 06:11 PM   #2
1971 25' Caravanner
scappoose , Oregon
Have just last weekend installed a batt bank/inverter/charger/eu 3000 system at a mountain cabin. The eu 3000 would directly charge the batts at 12 amps. Using the Xantrex inverter/charger, from the 120v outlet, can charge up to 100 amps.
Your system is different, but using 120v., to run the batt charger is much faster then the small 12v, direct output.
rangebowdrie is offline   Reply With Quote
Old 07-12-2009, 07:38 PM   #3
tpi
Trabuco Canyon , California
If your trailer is equipped with the same Parallax 7355 converter that mine uses I vote neither of your choices are very fast. My converter is at the rear of the trailer with a long wiring run which makes it even slower.
What I do is use a portable automotive 40 amp Xantrex 3 stage charger when I need a fast charge. Another option is a built in 3 stage converter-charger. Both can be powered by the generator.
tpi is offline   Reply With Quote
Old 07-12-2009, 08:56 PM   #4
jglabrown's Avatar
2005 16' International CCD
2009 23' International
Bainbridge Island , Washington
tpi: Do you leave the batteries connected to the trailer when you charge or do you disconnect and then charge? Is it better to charge one battery at a time or can both be charged together? I've always used the converter, but I like your idea.
jglabrown is offline   Reply With Quote
Old 07-12-2009, 09:33 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
This is my solution to the battery charging dilemma, XADC 60A Converter/Charger (Corded), the OEM Parallax just wasn't doing the job.
Plug into the Honda and let the converter do it's job.
The direct connection on the Honda works well for charging the TV battery,(not a deep cell).
I don't see a need to charge them seperately, after all the converter is wired to charge them together, you just need a good unit.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 07-12-2009, 09:36 PM   #6
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
The quickest why is to buy a new battery
I'm in the boat of just plugging a battery charger into the gen and charging them that way.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-12-2009, 09:37 PM   #7
tpi
I leave them connected and charge both batteries at a time. It is best to charge both together, they will draw more current from the charger. I do trust the charger won't exceed 14.4 volts and I leave them connected, but if you want to be super cautious hit the disconnect switch before charging them.
Old 07-25-2009, 04:01 PM   #8
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We have the OEM Parallax Converter (for now)... So...given that, am I understanding this correctly that the best way to recharge/top off dual sealed batteries with a generator is to use the 30 amp connection with the generator and charge through the converter? (The converter is located just forward of the axle in the 19' Bambi.) Or is it best to go directly to the battery with the DC connectors...(and if so should the batteries be disconnected by the disconnect swith...or is it OK to leave the batteries connected?) Thanks...
TB & Greg and Abbey Schnauzer
#3954
Old 07-25-2009, 04:51 PM   #9
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
What I would do is use a standalone battery charger plugged into the 120VAC Honda this would be the fastest way to charge.
There is no need to disconnect the batteries.
The 12VDC from the Honda will take a long time to charge the batteries as will the Parallax.
Garry
Old 07-25-2009, 05:38 PM   #10
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Thanks, Garry...not having a stand-alone battery charger then leaves us with 2 slower options. Our batteries never get really low because we have solar, but if we are out long enough dry camping they do need a little help from time to time depending on weather/sun/use factors.
#3954
Old 07-25-2009, 06:07 PM   #11
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
I have to agree with tpi. I was at a rally where only water was available. Some fellow AS's hooked up a regular bettery charger up to their generator. It was much faster than using the builtin converter/charger. Having a MH, I just ran the engine for a while & let the alternator do it's thing.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 07-25-2009, 06:58 PM   #12
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My InteliPower 9245 will shift into boost mode if the battery is low. Boost mode will charge the battery at a higher rate. You can also manually shift the converter into boost mode. Like everything else, more is not always better and you can damage a battery if you over charge it.
Richard
azflycaster is online now   Reply With Quote
Recharge Time henw Batteries, Univolts, Converters & Inverters 37 01-28-2010 02:41 PM
Batteries woodedareas Electrical - Systems, Generators, Batteries & Solar 5 04-30-2009 10:20 PM
batteries jhenry Member Introductions 5 10-19-2008 02:03 PM
Quickest route : major Hwy or backroads ? davidlaxson On The Road... 18 07-03-2007 10:45 AM
batteries dsmith Electrical - Systems, Generators, Batteries & Solar 7 03-15-2006 07:36 AM
