Old 12-20-2007, 08:26 AM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
?best battery charger-in garage
I think my old Schauer battery charger is ruining my batteries......but now it quit completely.
What is the cheapest, best, battery charger for use on my trailer batteries? "Smart, tapered" etc., is confusing What do you use?
I take my batteries out and bring them home to my garage. I have been putting them on a table and connecting my charger about every 2 months.
This a.m. the charger won't register anything on the dial???? One battery worked but the other seems to "short-out" the charger. I had it on "automatic"; it is supposed to start high on the dial and work its way to something low......
I am on my second set of Interstate SRM-27s. My charger seems to boil the batteries when it worked..... Maybe I have needed a new charger for a long time.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 12-20-2007, 08:48 AM   #2
"ALL" cheap chargers will boil batteries, since they do not have a "brain."
A new way to keep the charge up on batteries, is to install a small solar charger.
That will keep the batteries "topped off" without overcharging.
The only problem, is the charger needs sun light.
If you can wire it to be in the sun, you have solved the problem.
Small solar charges that work are as cheap as $20.00.
Old 12-20-2007, 11:49 AM   #3
Kistler's Avatar
2002 25' Classic
I appreciate the advice Solar would be nice but I like to have the batteries out of the trailer and home in the garage during the winter. At home I would have to run an exposed line outside probably, to the roof.
Does a Battery Minder Plus Surcharge IV qualify as acceptable? ....they are only $46.50 on the internet
Kistler
Old 12-20-2007, 12:07 PM   #4
gowyn's Avatar
2007 27' Safari FB SE
London , ontario
I've been using Battery tender or minders for years now, never had any problems.
gowyn is offline   Reply With Quote
Old 12-20-2007, 01:05 PM   #5
Kistler's Avatar
2002 25' Classic
Have you connected two, together on one BatteryMINDERplus?
Kistler
Old 12-20-2007, 01:24 PM   #6
Bambi75th's Avatar
2007 19' Bambi
Los Alamos , New Mexico
I use a BatteryTenderPlus on two batteries connedted in parallel. It works just fine.
Bambi75th is offline   Reply With Quote
Old 12-20-2007, 04:09 PM   #7
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Vector Battery Charger
Been using this unit for the last three seasons. Has worked very well
VEC1093A
A flexable 30w solar panel keeps them charged during the season
Vector Battery Charger - vector battery charger
Vector Car Battery Charger - auto car smart battery charger
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-20-2007, 07:59 PM   #8
2005 16' International CCD
Ogden , Utah
kistler:
I keep two Group 27 deep cycle batteries on one BatteryMinderplus - seems to work just fine. The instructions say that one charger can take care of up to 4 batteries wired together - but they must be the same rating and size.
RDM16CCD is offline   Reply With Quote
Old 12-20-2007, 08:15 PM   #9
lewster's Avatar
Naples, FL , Hood River, OR
One of the best of the 'new breed' of battery chargers is the BatteryMinder model 2248. It has settings for gel, liquid cell or AGM batteries and you can select a charge rate of 2,4 or 8 amps. It will diagnose the batteries condition and will go into auto de-sulfate mode of required.
I have been using them AND installing them as chassis charging systems on stationary MoHos for about a year now. They work great to maintain your batteries when not in use and are a true 3-stage charging system that will not harm your batteries, whatever type you use.
Old 12-20-2007, 08:33 PM   #10
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I used the BatteryMinder (1 amp) on my '77 Excella 500 with two Delco Voyager maintenance free batteries for 4 years and it always kept them charged. The BatteryMinderPlus is a 1.5 amp unit that would also work. I also bought a BatteryMinder which had an output of 4 amps and have used it on vehicles around the house with great success. All three units have my vote, the 4 amp model just gets the job done a little quicker.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-20-2007, 09:00 PM   #11
New Borockton , Alabama
Images: 21
Kistler,
You threw the word "cheapest" into the equation and that makes if more difficult but we have settled on the VDC BatteryMinder model 12248 for the exact reasons you asked except its $117 instead of a $20 battery boiler.
There is also the Deltran brand "tenders" that are often compared to VDC "Minders" but there really is no comparison when you consider full time desulfation. In addition to the desulfation, consider its settings of 2, 4 or 8 amps. Flooded, AGM, or Gel settings WITH temperature compensation and you just can't find a better or a more versitile garage or shop unit or I would already carry it.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 12-21-2007, 07:35 AM   #12
Kistler's Avatar
2002 25' Classic
Yes, I agree, I shouldn't have written "cheap/cheapest". I understand cheapest and best aren't in "harmony" in this case.
I shall take your advice and go with the batteryminder type. Now I am looking for a deal.....I want the best for the $, I guess.....sort of the reason we bought an Airstream.
Kistler
Old 12-21-2007, 09:25 AM   #13
Kistler's Avatar
2002 25' Classic
I ordered a 12248 from batteryplex.com It is a Christmas present for Brenda.
Kistler
Old 12-21-2007, 10:48 AM   #14
Images: 21
Make sure you also order the ABS 248 temperature sensor that goes with it. We include it but many companies do not.
Best battery charger for the money? Andy R Electrical - Systems, Generators, Batteries & Solar 27 10-01-2007 07:46 PM
battery charger ALANSD Batteries, Univolts, Converters & Inverters 8 09-16-2007 05:52 PM
HF Battery Charger dmaiden Batteries, Univolts, Converters & Inverters 10 11-03-2006 11:33 AM
Battery Charger luckydc Batteries, Univolts, Converters & Inverters 10 02-07-2006 08:04 PM
Solar Battery Charger Cstar Generators & Solar Power 2 01-04-2005 11:59 AM
