12-20-2007, 08:26 AM
2002 25' Classic
Oro Valley
?best battery charger-in garage
I think my old Schauer battery charger is ruining my batteries......but now it quit completely.
What is the cheapest, best, battery charger for use on my trailer batteries? "Smart, tapered" etc., is confusing What do you use?
I take my batteries out and bring them home to my garage. I have been putting them on a table and connecting my charger about every 2 months.
This a.m. the charger won't register anything on the dial???? One battery worked but the other seems to "short-out" the charger. I had it on "automatic"; it is supposed to start high on the dial and work its way to something low......
I am on my second set of Interstate SRM-27s. My charger seems to boil the batteries when it worked..... Maybe I have needed a new charger for a long time.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
12-20-2007, 08:48 AM
Corona
"ALL" cheap chargers will boil batteries, since they do not have a "brain."
A new way to keep the charge up on batteries, is to install a small solar charger.
That will keep the batteries "topped off" without overcharging.
The only problem, is the charger needs sun light.
If you can wire it to be in the sun, you have solved the problem.
Small solar charges that work are as cheap as $20.00.
12-20-2007, 11:49 AM
2002 25' Classic
Oro Valley
I appreciate the advice Solar would be nice but I like to have the batteries out of the trailer and home in the garage during the winter. At home I would have to run an exposed line outside probably, to the roof.
Does a Battery Minder Plus Surcharge IV qualify as acceptable? ....they are only $46.50 on the internet
Kistler
12-20-2007, 12:07 PM
2007 27' Safari FB SE
London
, ontario
I've been using Battery tender or minders for years now, never had any problems.
12-20-2007, 01:05 PM
2002 25' Classic
Oro Valley
Have you connected two, together on one BatteryMINDERplus?
Kistler
12-20-2007, 01:24 PM
2007 19' Bambi
Baltimore
, Maryland
I use a BatteryTenderPlus on two batteries connedted in parallel. It works just fine.
12-20-2007, 07:59 PM
2005 16' International CCD
Ogden
, Utah
kistler:
I keep two Group 27 deep cycle batteries on one BatteryMinderplus - seems to work just fine. The instructions say that one charger can take care of up to 4 batteries wired together - but they must be the same rating and size.
12-20-2007, 08:15 PM
Naples
One of the best of the 'new breed' of battery chargers is the BatteryMinder model 2248. It has settings for gel, liquid cell or AGM batteries and you can select a charge rate of 2,4 or 8 amps. It will diagnose the batteries condition and will go into auto de-sulfate mode of required.
I have been using them AND installing them as chassis charging systems on stationary MoHos for about a year now. They work great to maintain your batteries when not in use and are a true 3-stage charging system that will not harm your batteries, whatever type you use.
lewster
12-20-2007, 08:33 PM
1986 25' Sovereign
Southern Middle
, Tennessee
I used the BatteryMinder (1 amp) on my '77 Excella 500 with two Delco Voyager maintenance free batteries for 4 years and it always kept them charged. The BatteryMinderPlus is a 1.5 amp unit that would also work. I also bought a BatteryMinder which had an output of 4 amps and have used it on vehicles around the house with great success. All three units have my vote, the 4 amp model just gets the job done a little quicker.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
12-20-2007, 09:00 PM
New Borockton
, Alabama
Kistler,
You threw the word "cheapest" into the equation and that makes if more difficult but we have settled on the VDC BatteryMinder model 12248 for the exact reasons you asked except its $117 instead of a $20 battery boiler.
There is also the Deltran brand "tenders" that are often compared to VDC "Minders" but there really is no comparison when you consider full time desulfation. In addition to the desulfation, consider its settings of 2, 4 or 8 amps. Flooded, AGM, or Gel settings WITH temperature compensation and you just can't find a better or a more versitile garage or shop unit or I would already carry it.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
12-21-2007, 07:35 AM
2002 25' Classic
Oro Valley
Yes, I agree, I shouldn't have written "cheap/cheapest". I understand cheapest and best aren't in "harmony" in this case.
I shall take your advice and go with the batteryminder type. Now I am looking for a deal.....I want the best for the $, I guess.....sort of the reason we bought an Airstream.
Kistler
12-21-2007, 09:25 AM
2002 25' Classic
Oro Valley
I ordered a 12248 from batteryplex.com It is a Christmas present for Brenda.
Kistler
12-21-2007, 10:48 AM
New Borockton
, Alabama
Make sure you also order the ABS 248 temperature sensor that goes with it. We include it but many companies do not.
888-828-1893
Bestconverter.com
12-21-2007, 11:18 AM
2002 25' Classic
Oro Valley
oops!
Kistler
12-21-2007, 12:45 PM
1966 26' Overlander
Woodstock
, Georgia
Northern Tool has the battery minder on sale for 44.95, I just got one as my old charger not only stopped working, it sucked all the juice out of my Porsche battery!
12-21-2007, 01:58 PM
2002 25' Classic
Oro Valley
Did you get a 12248? If so I really goofed; paid $108 + shipping. By the way do I really care how hot my battery(ies) are?
If I do, I'll get the sensor thing for Brenda for a New Year present.
She has already gotten a new grinder for sharpening her yard tools and now the charger......she is getting too much
Kistler
12-21-2007, 02:23 PM
1977 27' Overlander
Trotwood
, Ohio
Thank U all for the above info. I just bought 2 new group 27 batterys for Miss Kitty. I did buy a float charger that I have connected to them in the shop they are not yet installed because of repairing some PO issues.
12-31-2007, 06:52 AM
1966 26' Overlander
Woodstock
, Georgia
I got the 12117 and the battery check device that came as free bonus. It was 44 bucks at NT. I mainly will be using it on the 911 as that car sits during the week. Wish I had gotten it before my Yellow Top died.
11-17-2008, 11:08 PM
I approve of this message
2006 28' International CCD
Redmond
Curious what you recommend for 6-volt charging? The BatteryMINDer 12248 for series connected or the 1-amp 12106 for individual 6-volt battery?
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Best battery charger for the money?
Andy R |
Electrical - Systems, Generators, Batteries & Solar |
27 |
10-01-2007 07:46 PM |
battery charger
ALANSD |
Batteries, Univolts, Converters & Inverters |
8 |
09-16-2007 05:52 PM |
HF Battery Charger
dmaiden |
10 |
11-03-2006 11:33 AM |
Battery Charger
luckydc |
10 |
02-07-2006 08:04 PM |
Solar Battery Charger
Cstar |
Generators & Solar Power |
2 |
01-04-2005 11:59 AM |
