Old 01-22-2008, 11:32 AM   #1
2007 19' Safari SE
Washington , Washington, D.C.
Best Battery
Simple question...I have a 2006 Airstream Bambi. Want to have some back up 12 volt batteries. What would you suggest as to the brand name of best battery? Thanks, Tom
Also, is there a way to confirm that when trailer is plugged into tow vehicle that is in fact charging the batteries ?
tnickels is offline   Reply With Quote
Old 01-22-2008, 11:56 AM   #2
1999 25' Safari
Fairburn , Georgia
Hello, I have no preference for name brand batteries, but have found over the years with many autos and motorcycles, that none seem to be any better than others. I have had good luck with batteries from Batteries Plus, and they are less expensive.
As for your battery charging, plug the trailer into the tow vehicle, and with the TV engine running, measure the voltage at the battery terminals. It should read approx. 14.5 volts. It takes 14.5 volts to properly charge a 12 volt battery.
JackMac is offline   Reply With Quote
Old 01-22-2008, 12:07 PM   #3
Kajtek1's Avatar
1965 22' Safari
Orinda , California
If the have the space, nothing beats golf cart batteries in RV. You need 2 and Sam's sells them for about $65.
Costco is selling automotive batteries with 100 months warranty and they really last.
Kajtek1 is offline   Reply With Quote
Old 01-22-2008, 12:08 PM   #4
Images: 59
LOL! On these forums, there are no simple questions, and certainly no simple answers.
I would say buy a Rolls if price is no object. But then, why would you pay a couple of hundred $$ for a "back-up" battery.
The best combination of power and value is a Trojan.
Or maybe you would prefer an AGM battery? Lifeline batteries seem to be the preferred brand.
Old 01-22-2008, 12:16 PM   #5
Kajtek1's Avatar
1965 22' Safari
Orinda , California
Trojan battery bis having good ratings, but when I researched them, all golf cart dealers in my county dropped Trojan for poor customer service.
Sure picking up $60 battery at local Sam's beat driving 40 miles for $120 Trojans.
Old 01-22-2008, 02:22 PM   #6
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
Install a Link 10 monitor. It will answer all your charging / discharging questions. There are other similar products to choose from as well.
See Xantrex Technology Inc. - Link 10 - Product Information
campadk is offline   Reply With Quote
Old 01-22-2008, 03:53 PM   #7
mandolindave's Avatar
Best battery?????, or best battery for you ??
The world of batteries according to Dave...........
1) The most expensive high performance auto batteries usually don't outlive the medium priced medium performance auto batteries. The expensive batts use thinner plates to achieve better performance. ( studies show )
2) Don't mix old and new batts even if they are the same model.
3) Auto batts can be run down from 10 to 20 times before they are shot.
Auto batts don't usually get run down very many times. Trojans and Optima AGMs can be run down several hundred times.
I use Trojan golf cart batteries because the are cheap, and they perform
I use Optimas AGMs because they don't need venting, and they perform
mandolindave is offline   Reply With Quote
Old 01-22-2008, 04:58 PM   #8
Dwight's Avatar
1999 34' Excella
Joshua , Texas
I have 8 of the Optima group 27 D31M batteries and they have worked great and no venting.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 01-22-2008, 05:09 PM   #9
lewster's Avatar
Naples, FL , Hood River, OR
One Word....................
lifeline !!!!!!!!!!!!!!!!!
Old 01-22-2008, 05:20 PM   #10
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Ditto.
Richard
Old 01-22-2008, 05:47 PM   #11
1975 29' Ambassador
Reno , Nevada
Not a bad start! We have the TDCGC (true deep cycle golf cart) and AGM (Lifeline. Optima) advocates in early. This can get interesting ;-)
Dave has some good observations.
What you should look for in batteries is a reputable retailer who will stand behind warranties and sells a lot of batteries. Get the biggest that will fit. Get batteries rated for RV/Marine deep cycle type use. Get enough battery so you don't run them down more than 50% before recharging. Don't get so much battery that you don't normally discharge less than 15%.
The first place to put your money, though, is in a good converter and battery maintainer. You want an intelligent 3 stage charger with storage maintenance features that minimize sulfation. The WFCO and PD+ChargeWizard are two examples. The Battery Minder Plus is an example of a maintainer only that has a desulfation technique.
There are only a few manufacturers for these batteries and it is a mature business. They all produce good batteries. Which battery you get in a particular line is going to make more difference than which brand name you go for.
If you want a long and happy relationship with your batteries, don't abuse them.
Old 01-22-2008, 05:56 PM   #12
Kajtek1's Avatar
1965 22' Safari
Orinda , California
On the contrary, I have experience that batteries are like women.
Good treatment doesn't make good relation.
I used to have diesel wagon with 2 batteries. I bought a pair of batteries for it, but about 3 years later famous Oldsmobile 350 diesel gave up.
So after junking the wagon I separated the batteries. One went on the shelf where was regularly charged, the other to my wife car.
My wife was abusing the battery quite a bit. Once she went shopping and 3 hr later I've got a call that she forgot about headlights. When I arrived even the dashboard lights would not glow. The battery survived that just fine.
About year later she drove the car on rainy Saturday afternoon with lights on and parked it at house. Following morning we couldn't turn the engine for church trip (about 18 hr battery was shorted) . I jumped the battery from another battery and drove to the church. The battery survived that.
So the battery babied on the shelf died in about 5 years, while the one shorted several times gave us 7 years of service.
Old 01-22-2008, 09:50 PM   #13
1975 29' Ambassador
Reno , Nevada
ya' know, it really gets amazing how far some go to create a contest - or is there perhaps a misunderstanding here?
What you illustrate is that float service is indeed more abusive than occasional deep discharges. That is well known.
Yes indeed abuse your batteries: run them down dead regularly; let them sit for weeks in a discharged state at desert temperatures; overcharge regularly and don't keep the electrolyte level up; -- you really think that is the way to getting the longest life and best service from a battery?
The data I have seen is that more than 80% of battery failures are due to sulfation. Whether this aging is nominal, premature, or whatever, it is reduced by not abusing your batteries.
When you buy a new battery, one thing you really need to look for is the manufacturer's date code. The longer that battery has sat being babied on the shelf waiting for you to buy it, the more abused it is in starting its service with you.
Lead acid batteries need proper care. That means that discharge cycles bring them down at least 15% but no more than 50%. That means that they are recharged promptly, vigorously, and properly. That means that they are given sulfation prevention charging if not in use for more than a couple of weeks. That means that they are not overcharged or held at too high a float so electrolyte loss is minimized. That means distilled water is used if necessary to keep the elelctrolyte above the plates and below the fill tube. That means that they are not subject to hot conditions.
I would really like to know what it is about my message that prompts an immediate " On the contrary" response. I tried to offer something useful, pertinent to the thread, well known, well founded, and well accepted yet the first response does not even make a base attempt to find anything constructive? Maybe I am getting oversensitive but, good grief, what do I do that stimulates this sort of thing? I'd like to think I am contributing something worthwhile and responses like this hurt.
update: edited to fix a few typos, probably still a few more. must be upset. time to take a break
Old 01-22-2008, 10:32 PM   #14
Kajtek1's Avatar
1965 22' Safari
Orinda , California
You sound like "don't confuse me with the facts, I have my mind already set"
Nothing personal, but facts are facts. To add to my point, this winter I went to my motorhome storage. Turned out that although I pulled the main switch off, the engine 2 batteries got discharged by electronic circuit. Don't know for how long they have been shorted, but I parked the motorhome 3 months earlier.
The 5-years old Costco batteries charged back to full performance.
How is that tor the theory? Nothing personal, I know "scientific research" as well.
Do I need a battery....? jesus mike Batteries, Univolts, Converters & Inverters 4 11-28-2007 09:26 PM
battery frederic.c01 Batteries, Univolts, Converters & Inverters 2 06-09-2004 06:28 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
Getting a new Battery ChrisAich 2002 - 2005 International 0 10-09-2003 02:25 PM
