Old 04-14-2009, 06:01 PM   #15
Pacerized's Avatar
1981 25' Excella II
Dillon , Colorado
Images: 11
It looks like you pay approx. 5 times as much per amp hour with the lifeline or the optima then you do for a wet cell deep cycle battery. I don't think they last 5 times as long, so since you bring up value for the $, I'd look into a good wet cell battery as an option.
Pacerized is offline   Reply With Quote
Old 04-14-2009, 08:07 PM   #16
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink
Value is in the eye of the Streamer.
BTW... Lifelines are a "wet" cell battery.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 04-29-2013, 09:46 AM   #17
1973 29' Ambassador
Seattle , Washington
I know this is an old thread, but wanted to share. since my univolt killed my interstate g27, I upgraded to a PD9245.
At the same time, I was looking for ways to increase power capacity, so instead of another single G27 in the outside compartment, I raised the "floor" of the closet curbside between the bunk and the bathtub to make room for (I think) up to three AGM batteries. I recently scored two G27 100AH batteries from amazon for a crazy price! ($168 each/delivered) This was the cheapest price I've found anywhere, per AH, for AGMs.
Two disclosures
1. yes, I know you technically should vent AGMs. I'm a chemist and will evaluate once they're in operation to determine if I need to build and vent a box for them
2. Yes, I know the universals are not seen as great as the lifelines, but these are a fraction of the price.
AGMs were selected for the (hopeful) ability to be used inside the cabin, and their ability to not self discharge rapidly, since coach is stored an hour away from me most of the time.
Universal Power Group 45978 Sealed Lead Acid Battery - Amazon.com
dcheshire is online now   Reply With Quote
Old 04-29-2013, 01:31 PM   #18
Question To good to be true...
Two disclosures
I don't see anywhere in the description that they are AGM batteries.
100ah sealed grp27.
The AGM's we purchased were described as such, same with the Optima's.
PFC
RLC
Old 04-29-2013, 02:10 PM   #19
100ah sealed grp27.
OOOp's
On edit.... found it noted in the fine print...
PFC
RLC
Old 04-29-2013, 02:21 PM   #20
1973 29' Ambassador
Hi Bob,
Great question. You caused me to double check the specs on the MFG site and it is AGM http://upgi.com/Themes/leanandgreen/...oads/45978.pdf
It's no lifeline, but.
PS, love your posts, thanks for being such an active member of this community!
Old 04-29-2013, 02:48 PM   #21
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
OOOp's
I had to use the "Find" feature on FireFox to locate it. It wasn't featured prominently at all.
Vaughan
Old 04-29-2013, 04:18 PM   #22
lewster's Avatar
Naples, FL , Hood River, OR
You'll pardon my cynicism, but NO amount of dollar savings will replace a superior product made in the USA with a 5 year warranty for a Chinese knock-off that will probably be dead in 3 years.
You simply can not duplicate the superior construction of a Lifeline with a cheap imitation and expect the same service! I hope you prove me wrong, but my experience tells me otherwise............
You may think that I am showing bias as I sell the Lifeline brand, but that decision came after 4 months of research and many conversations with many of the major battery manufacturers....a decision that was not reached lightly.
Old 04-29-2013, 07:09 PM   #23
X2!
4th Season...going strong.
PFC
RLC
Old 06-14-2013, 01:40 PM   #24
2004 25' Safari
Laramie , Wyoming
I know this may seem like a very silly question but what does AGM stand for?
mgap is offline   Reply With Quote
Old 06-14-2013, 01:54 PM   #25
2005 19' Safari
GLENDALE , AZ
See explanation at this link: VRLA battery - Wikipedia, the free encyclopedia
Old 06-14-2013, 04:17 PM   #26
lewster's Avatar
Originally Posted by Phoenix View Post
I don't know what idiot wrote that entry to Wiki, but most of what he wrote is exactly 180º out of phase with actual facts regarding AGM batteries.
Comparison with flooded lead–acid cells[edit]
VRLA batteries offer several advantages compared with flooded lead–acid cells. The battery can be mounted in any position, since the valves only operate on overpressure faults. Since the battery system is designed to be recombinant and eliminate the emission of gases on overcharge, room ventilation requirements are reduced and no acid fume is emitted during normal operation. The volume of free electrolyte that could be released on damage to the case or venting is very small. There is no need (nor possibility) to check the level of electrolyte or to top up water lost due to electrolysis, reducing inspection and maintenance.[5]
Because of calcium added to its plates to reduce water loss, a sealed battery recharges much more slowly than a flooded lead acid battery.[6][7] Compared to flooded batteries, VRLA batteries are more sensitive to high temperature,[citation needed] and are more vulnerable to thermal run-away during abusive charging.[1] The electrolyte cannot be tested by hydrometer to diagnose improper charging, which can reduce battery life.[8][7]
AGM automobile batteries are typically about twice the price of flooded-cell batteries in a given BCI size group; gel batteries as much as five times greater. VRLA batteries:
Are less reliable[vague] than flooded lead acid [2]
Have longer recharge time than flooded lead-acid.
Cannot tolerate overcharging: overcharging leads to premature failure.[citation needed]
Have shorter useful life.[citation needed]
Discharge significantly less hydrogen gas.
"Because of calcium added to its plates to reduce water loss, a sealed battery recharges much more slowly than a flooded lead acid battery."
FALSE! An AGM battery, due to it's much lower internal resistance, charges in a much shorter amount of time than a comparable liquid lead acid battery
"Compared to flooded batteries, VRLA batteries are more sensitive to high temperature,[citation needed] and are more vulnerable to thermal run-away during abusive charging."
PARTIALLY FALSE! AGM batteries are far less sensitive to higher operating temperatures than a comparable liquid lead acid battery. Yes, they are more sensitive to extreme overcharging (above 15.5VDC at 77ºFº) and they will outgas thru the one-way valve at this condition over extended periods of time, but you will boil a liquid lead acid battery dry in a similar situation.
"Are less reliable[vague] than flooded lead acid"
FALSE! Without data to back up this sprurious claim, it is meaningless. I have several large banks of Lifeline AGM batteries currently on their 9th year of service in RVs and still show 95% of the original capacity. How is that less reliable?
This entry was obviously written either by a moron or a troll working for the liquid lead acid battery industry. SHOW ME THE FACTS!!!!!
Old 06-14-2013, 06:01 PM   #27
2005 19' Safari
GLENDALE , AZ
This link was posted merely for the description of "AGM batteries". At the top of this Wikipedia article, a notation seems to imply that the text needs additional fact checking. Perhaps, it would have been clearer and more accurate to just post the two short paragraphs related to "Absorbed Gas Mat", which appear to be sufficient for this discussion. (See below.)
Extract from Wikipedia article previously referenced:
AGM batteries differ from flooded lead acid batteries in that the electrolyte is held in the glass mats, as opposed to freely flooding the plates. Very thin glass fibers are woven into a mat to increase surface area enough to hold sufficient electrolyte on the cells for their lifetime. The fibers that compose the fine glass mat do not absorb nor are affected by the acidic electrolyte. These mats are wrung out 2–5% after being soaked in acids, prior to manufacture completion and sealing.
The plates in an AGM battery may be any shape. Some are flat, others are bent or rolled. AGM batteries, both deep cycle and starting, are built in a rectangular case to BCI battery code specifications.
Battery vent - or AGM pauly g Batteries, Univolts, Converters & Inverters 15 01-23-2008 08:32 AM
Deka Sea Mate AGM Battery Stream 1529 Batteries, Univolts, Converters & Inverters 4 07-27-2007 12:08 AM
AGM Batteries? Boondocker Batteries, Univolts, Converters & Inverters 33 06-03-2007 06:23 AM
New Progressive Dynamics convertor, AGM battery, and Pendant questions wacnstac Batteries, Univolts, Converters & Inverters 16 05-09-2007 09:12 PM
AGM battery question LuminumTraila Batteries, Univolts, Converters & Inverters 3 03-01-2005 04:56 AM
