Old 12-29-2019, 09:40 PM   #1
2019 30' Classic
Belen , New Mexico
BattleBorn teardown
For those that wondered if the BattleBorn batteries are worth the price, you need to see this video.
Ephraim is offline   Reply With Quote
Old 12-29-2019, 11:02 PM   #2
batman's Avatar
1964 22' Safari
modesto , California
I have seen Will tear down other batteries. BattleBorn seems to be one of the best over the counter options. So far.
batman is offline   Reply With Quote
Old 01-09-2020, 09:12 PM   #3
waninae39's Avatar
2017 22' Sport
NCR , Ontario
here is a good cost /performance of BB lion vs. a lead acid double the size
https://battlebornbatteries.com/brea...etter-battery/
Name:	true cost of lion.JPG
waninae39 is offline   Reply With Quote
Old 01-10-2020, 12:16 AM   #4
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Yes, it is a very good video. Battleborn has its cells made in China, but they assemble the battery in the US in their own plant. Very well made as Will confesses in the video. All his other battery teardowns are hilarious to watch. None come close to what he found inside the case of a Battleborn.
x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
turk123 is offline   Reply With Quote
Old 01-10-2020, 08:52 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
More good stuff
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Old 01-10-2020, 10:39 AM   #6
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
It certainly gives you something to seriously think about whenever you see much less expensive lithiums and think you have hit the jackpot. With some things you really get what you pay for and Battleborn's seem to be one of those things. Now I just have to save my pennies
thewarden is offline   Reply With Quote
Old 01-11-2020, 04:50 PM   #7
2019 22' Sport
Carlsbad , California
Did anyone else pick up on the upcoming update to the batteries?? Internal temperature regulation... thatís a big deal for those who want to winter camp, or even storage outdoors in cold climates.
Also interesting was the comment around floating at 13.4 being totally fine for the battery. Makes me think that with a solar panel(s) and controller taking care of the full charge (getting to 100%) demands, that the standard charger in newer Airstreams are fine to keep when on shore power.
Thanks for posting that, and Iíll hold off until the new internal updates are released in Q1.
Prettygood is offline   Reply With Quote
Old 01-11-2020, 05:32 PM   #8
2018 30' Classic
Williamsburg , VA
Are the chargers on the 2018 Classic compatible with these batteries?
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
primepower is offline   Reply With Quote
Old 01-13-2020, 10:59 AM   #9
2020 Classic 33 on order
Box Elder , South Dakota
No the AS chargers are not fully lithium compatible. The latest ones are 3 stage chargers, which is good, but are not adjustable for the specifics of lithium batteries. They are setup for AGM or lead acid depending on the original batteries that came with the trailer.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Old 01-13-2020, 05:21 PM   #10
2018 30' Classic
Williamsburg , VA
Thank you for the reply. Consider I never dry camp I think I'll stick with my AGM batteries. I only camp with full hookups anyway.
2018 Classic 30
2012 F250 6.7l
Old 01-13-2020, 08:12 PM   #11
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I replaced my 4 Interstate 6V batteries (77 pounds each), with 4 of the Battleborn's last summer. (I'd replaced the stock inverter with a MSH30 Magnum Inverter/Charger in 2015 when I took delivery of my '15 Classic. I also installed an AM Solar package with 6 100W panels. The performance of the Battleborn's has been wonderful. I often run one A/C on batteries when we stop for lunch. I watched the Battleborn's carefully. Not only did they handle the load with ease (yes, I have Easy Starts on both A/C's), if it was a sunny day, they were fully charged when we stopped for the night. No doubt about it. Going to lithiums is an expensive proposition, but I like the fact that I've dropped several hundred pounds as well as the knowledge that there are umpteen cycles ahead of these batteries.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 01-13-2020, 10:32 PM   #12
waninae39's Avatar
2017 22' Sport
NCR , Ontario
get the victron converter/inverter. it can easily be tuned to Lion of any make/model
Battleborn golfcart battery & 2,000 watt inverter installation TouringDan Batteries, Univolts, Converters & Inverters 36 08-17-2019 10:04 AM
Upgraded 2017 Sport 22 stock battery to 100 AH BattleBorn lithium Jhess Batteries, Univolts, Converters & Inverters 31 10-21-2018 01:04 PM
7.3 Minuet Teardown bebling All Argosy Trailers 10 03-17-2013 03:12 PM
Hensley teardown/repaint GreggH Towing, Tow Vehicles & Hitches 3 03-17-2012 12:54 PM
Full Teardown Required? TCHANNEL Repairing/Replacing Floor &/or Frame 5 11-29-2009 08:59 PM
