Old 12-20-2010, 09:25 AM   #29
_
clearly the charger isn't charging.
the simplest approach is to use a traditional charger for these few days,
whenever shore power is available.
IF rv battery use is limited to the fridge electronics and cooling is done with lpgas this will get ya through the trip.
while parked/plugged in the furnace/water pump and lights will still require 12v but direct REcharge as needed will work.
the trailer brakes SHOULD function via the 7pin, but please be sure of that.
____________
it's never fun to make major repairs while in route or on a short trip...
especially when the goal of the trip is a few days of family fun.
shipping parts overnight is crazy expensive and u might be hurried into picking the wrong (expensive) replacement.
you will be passing by several BIG camping worlds, so it is possible to stop and buy the gear.
but unless you wanna replace the uni' with another uni', the process of install/upgrade will use a full day (or more)
_____________
sometimes it is necessary to modify plans to accomplish the main goals.
ultimately the memories should be about disney and kids.
so if it's necessary to ditch the fridge food or use ice chests or buy a small 12v cooler (plugged into the tow vehicle)...
i'd simply wait on replacing/upgrading the trailer charge system,
till the fun part is over and the rig is back in dry dock.
cheers
2air'
Old 12-20-2010, 05:54 PM   #30
Certainly Blessed
rebelstand's Avatar
1971 27' Overlander
Waiting to Escape.... , Somewhere between sanity and insanity ... on the brink of both.
Shawn has bought a battery charger. Since 11 of our lights run on 12v and only 3 run on shore power and he has work until Thursday, trying to do big repairs just doesn't make sense. Although, he's had to repair two small water pipe leaks today!!
A very sincere thanks to everyone!
Nicki
TAC OK-42
Come See Minnie Mouse at the TAC Walt Disney World Fort Wilderness Rally
http://airstreamingdreaming.blogspot.com
"Get busy livin', or get busy dyin'." - The Shawshank Redemption
rebelstand is offline   Reply With Quote
Old 12-20-2010, 06:03 PM   #31
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you are in the market for a converter to replace the Univolt. There is an Inteli-Power PD9245C on EBay for $129.59 including shipping. It has a 45 amp capacity which should work for you.
If you decide to upgrade; there are plenty of people in the forum to walk you thru it.
I for one will be happy to help. Along with others that helped; we walked a lady thru the complete rewire of her trailer. She had no experience prior to this.
If you go to the member lucymcdog and follow the post labeled "Electrical & 12v System" thread. It will show you how we did it. Caution! it is a long read.
WE DO PICTURES AND EVERYTHING!
Old 12-20-2010, 07:38 PM   #32
Certainly Blessed
rebelstand's Avatar
1971 27' Overlander
Thanks I will forward that to Shawn. I am sure it will help him out. Thanks so much!
Nicki
TAC OK-42
Old 01-02-2011, 07:33 PM   #33
Certainly Blessed
rebelstand's Avatar
1971 27' Overlander
Just wanted to let you know..
we bought a battery charger that got us through the trip safe, warm & lighted.
There never was a "hum" from the univolt again.
Shawn took out the "Univolt" today. Here's the pic:
Pretty sure this was a PO modification. We will be shopping for a new one soon.
Nicki
TAC OK-42
Old 01-02-2011, 07:38 PM   #34
SteveH's Avatar
Common Sense , Texas
Well that's nothing but a battery charger, and not a very good one either. Also, it's not big enough (not enough capacity).
Glad you were able to continue with your trip OK.
Regards,
Steve
Old 01-02-2011, 08:57 PM   #35
Certainly Blessed
rebelstand's Avatar
1971 27' Overlander
Exthemius requested I show you this picture as well.
Naturally the only thing we could see was the fusebox portion. Since it had always worked we didn't ever pull it out to look at it. I have to say they did an excellent job of cutting the original metal box.
Nicki
TAC OK-42
Old 01-03-2011, 06:38 AM   #36
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
Yes, that was a helluva surprise when I took it out and found that POS in there....walked into the house giggling. Anyway, here's what we're planning on buying and hooking up to the existing distribution panel: PD 9245C 45 Amp RV Converter/Charger.
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
Old 01-03-2011, 07:00 AM   #37
SteveH's Avatar
That should do just fine.
Regards,
Steve
Old 01-04-2011, 07:31 AM   #38
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Converter
If you go to www.keithsrvsurplus.com You can get the same converter new for less than $125.00. Go to "Interior Parts"
Old 02-07-2011, 11:29 AM   #39
1975 24' Argosy 24
Burlington , Ontario
Firstly How old is your Battery.? If it is a deep cycle then it should be good for up to 5 years but not much more. How is the water level in the battery.
Corrosion is not always noticeable. a bright connection is needed. Check the isolation diode in the Univolt.
The univolt is a 6 volt transformer with a doubler circuit to give you the 12VDC. a leaky diode can lower the charge rate.
CHECK ALL CONNECTIONS LEADING TO THE BATTERY
Rae
raebaker06 is offline   Reply With Quote
Old 02-07-2011, 12:15 PM   #40
Addicted
exthemius's Avatar
1971 27' Overlander
Images: 16
Rae
It wasn't the battery or the univolt -- it was the fact that the "univolt" that we could see was only the fuse panel.....we discovered that the PO simply put in a small battery charger in it's place we removed it. This has since been corrected, as seen here:
Airstreaming Dreaming: Intelli-power Installation.....DONE!
-Shawn
TAC OK-42
Old 02-07-2011, 12:59 PM   #41
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Too Small
The wires coming out of your converter are way to small. What size is the big fuse in the fuse panel where these wires connect? If it is a 30 amp fuse you need at least #10 wire. Maybe it's just the photo but they don't look like #10. If the fuse is larger you need larger wire.
Old 02-07-2011, 02:56 PM   #42
Addicted
exthemius's Avatar
1971 27' Overlander
Images: 16
It's 12 gauge wire, the instructions that came with the unit said the rating was for 12 to 2. The length is less than 2 feet, and the amp is 45....according to the various wire gauge tables that I looked at, I needed 18 gauge for 3' @ 40amps and 16 gauge for 3' @ 50 amps.....I don't think I did anything incorrectly, but I could be wrong.
-Shawn
TAC OK-42
AC Drain & Battery Charge la4photo 1974 - 1979 Sovereign 4 05-10-2009 05:00 PM
Battery loses charge when parked ashe Batteries, Univolts, Converters & Inverters 9 02-04-2009 11:29 AM
Battery Charge frscott Electrical - Systems, Generators, Batteries & Solar 23 12-05-2008 08:48 AM
Battery Charge from Tow Vehicle Wardinbb Batteries, Univolts, Converters & Inverters 13 12-08-2004 05:35 PM
How to wire truck to charge TT battery? femuse Electrical - Systems, Generators, Batteries & Solar 19 04-09-2003 10:23 AM
