Old 03-22-2014, 01:30 PM   #1
rperrym's Avatar
2017 28' Tommy Bahama
2015 28' Flying Cloud
2014 25' FB Eddie Bauer
Hot Springs Village , Arkansas
Battery Watering Systems
Has anyone installed a battery watering system, similar to the Qwik-Fill Dual 12 Volt battery watering system? On our Airstream, with the battery cables attached, it is fairly difficult to get water into the cells. This system seems to make it much more convenient. I assume there are other types as well.
Just wondering if anyone has used them and if they work as well as the write-up indicates.
Rick
rperrym is offline   Reply With Quote
Old 03-22-2014, 01:40 PM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 55
As you indicate, the battery cables usually present a clear access problem. I find it easier to remove the batteries about every 7-9 months, test, clean the batteries and the compartment, rotate the batteries (the one nearest the positive will always receive the greater charge and require more distilled water) and remount after cleaning all terminals and applying dielectric grease. Record the test results in your book for future reference.
After doing this preventive maintenance procedure regularly you will not have any worries about your batteries.
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 03-22-2014, 03:07 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A turkey baster works reasonably well for adding water to batteries. Or a "Cajun injector" syringe.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-22-2014, 03:21 PM   #4
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I use one of those sport drink bottles with the squirt type cap. Also good for adding oil to the lawn mower and other small engines. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-22-2014, 04:16 PM   #5
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
When the batteries are replaced, go to AGM's. No maintenance required...
Richard
azflycaster is online now   Reply With Quote
Old 03-22-2014, 04:20 PM   #6
rperrym's Avatar
On the post about AGM's, do you have to change battery charging systems when you switch?
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 03:33 PM
Battery Box Modification Options Ridgerunner3 Batteries, Univolts, Converters & Inverters 5 10-09-2013 05:28 PM
2004 Land Yacht Chassis Battery? RAG Land Yacht/Legacy Motorhomes 11 02-01-2012 08:19 AM
