Old 03-21-2016, 05:25 AM   #1
MOS
2016 28' Flying Cloud
Queensbury , New York
battery voltage readings?
Have a 2016 FC28W.
Twin 12v interstate group 24 batteries .
When the battery monitor reads 13.6 0r whatever, is this one battery??
I don't see how that can be the same on both.
Mike
MOS is offline   Reply With Quote
Old 03-21-2016, 05:28 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Your batteries are connected in parallel so the voltage will be the same.
Larry
lsbrodsky is offline   Reply With Quote
Old 03-21-2016, 05:29 AM   #3
2014 22' FB Sport
Barrie , Ontario
As the are wired in parallel you will not see the differences between the two. You would have to disconnect them to see ther individual voltages. As long as they are identical and installed new together you are usually ok unless one gets a shorted cell....
Lhunter59 is offline   Reply With Quote
Old 03-21-2016, 06:10 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
13.6VDC is the output of your converter, not the actual battery voltage. To get the actual battery voltage, disconnect from shore power (or place the use/store/ switch in the 'store' position and let the batteries rest for a few hours. Then take a reading at the batteries with a volt meter.
Old 03-21-2016, 06:44 AM   #5
MOS
Thanks for the info !
Cat scale readings printman Towing, Tow Vehicles & Hitches 17 08-11-2015 08:12 PM
Too High Battery Voltage? TankerIP Batteries, Univolts, Converters & Inverters 14 08-08-2010 08:58 PM
Low voltage... converter or battery problem? patrickdylan Batteries, Univolts, Converters & Inverters 5 08-22-2009 09:24 PM
Low-Voltage Battery Alarm rseagle Electrical - Systems, Generators, Batteries & Solar 14 04-19-2006 08:19 PM
voltage at battery? 3Ms75Argosy Electrical - Systems, Generators, Batteries & Solar 1 07-27-2005 04:25 PM
