Old 04-10-2015, 04:17 PM   #1
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Battery Voltage
I started to wake up the trailer today after its winter hibernation - put the battery back in and fired up the furnace to put a load on it. Voltage out of the garage was 12.77 volts. After a couple of hours of the furnace cycling on and off (below freezing last night and just above today) I checked the voltage from inside the trailer with my plug in voltage meter. After the furnace shut off the voltmeter read 12.4 volts. I seemed a little low so thought I would check at the battery with the multimeter - it read 12.60 volts.
So my question is: is it normal to have a such difference in the voltage between the battery and inside the trailer?
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 04-10-2015, 04:20 PM   #2
dznf0g's Avatar
Oswego , Illinois
Well, it depends on how many mechanical connections are between the battery post and the spot where you checked inside the AS....and how tight and clean those connections are.
Every connection has a voltage (drop) penalty, so what you see could be normal, or not. Try cleaning each connection and re tightening each. Star washers are never a bad idea, as they really "bite" and make good mechanical connections.
-Rich-
Old 04-10-2015, 05:12 PM   #3
RangerJay's Avatar
2002 19' Bambi
Images: 44
Thanks - I didn't know that - the connections that come to mind quickly would be into and out of the converter and the connections into and out of the 12V panel - am I on the right track?
Jay
(Oscar Wilde)
Old 04-10-2015, 06:37 PM   #4
1974 Argosy 20
Kooskia , Idaho
Also the fuse connections, and just the fact that there is loss in the wire which is always going to be there. I have seen far worse than the 0.2 voltage drop you are seeing. Of course, remember that you have the ground (negative 12 volts) side to consider as well as the + side.
However, I note you were measuring at rest, with no load. That makes me think that your meters are not agreeing with each other. Check with the same meter only.
Battery State of Charge-Voltage Chart Mexray Batteries, Univolts, Converters & Inverters 1 09-08-2010 01:21 PM
Too High Battery Voltage? TankerIP Batteries, Univolts, Converters & Inverters 14 08-08-2010 08:58 PM
Low voltage... converter or battery problem? patrickdylan Batteries, Univolts, Converters & Inverters 5 08-22-2009 09:24 PM
Low-Voltage Battery Alarm rseagle Electrical - Systems, Generators, Batteries & Solar 14 04-19-2006 08:19 PM
voltage at battery? 3Ms75Argosy Electrical - Systems, Generators, Batteries & Solar 1 07-27-2005 04:25 PM
