Old 01-22-2008, 08:18 PM   #15
pauly g's Avatar
1960 22' Safari
Oceanside , California
Thanks for the pics, kajtek. No, my trailer does not have a vent like that. The only access to the battery is to lift the gaucho cushion. I am starting to think that the AGMs might be worth the cost. I'm stil uncertain about the compatibility with the charge wizard. I read somewhere that the charge voltage is too high for these in hot weather.
pauly g is offline   Reply With Quote
Old 01-23-2008, 08:32 AM   #16
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
This is from the RV Net discussion site. Looks like they have one charge wizard for gel batteries and one for standard/AGM batteries.
Here is an email from Keith at Progressive Dynamics. As you can see, they don't have a special charge wizard for AGM batteries.
"Jim,
You do not need a special type of charge wizard. AGM batteries charge somewhat like Lead Acid and the Wizard is default lead acid and AGM.
Deka Sea Mate AGM Battery Stream 1529 Batteries, Univolts, Converters & Inverters 4 07-27-2007 12:08 AM
AGM Batteries? Boondocker Batteries, Univolts, Converters & Inverters 33 06-03-2007 06:23 AM
New Progressive Dynamics convertor, AGM battery, and Pendant questions wacnstac Batteries, Univolts, Converters & Inverters 16 05-09-2007 09:12 PM
Cabelas AGM batteries wacnstac Batteries, Univolts, Converters & Inverters 26 10-13-2006 07:22 AM
AGM battery question LuminumTraila Batteries, Univolts, Converters & Inverters 3 03-01-2005 04:56 AM
