Old 02-14-2011, 11:44 AM   #1
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Battery Testing
Lucy is now quickly approaching 5 years old (June 1) and we are still running on her original 12 volt batteries. How long are these batteries supposed to last? I have gotten the impression from reading other threads that you are lucky if you can get 3 years out of a battery. We have used Lucy a whole bunch (800 nights/70,000 miles) which may have something to do with her batteries' longevity.
What is the best way to test Lucy's batteries to see if they are still up to par or really need to be replaced?
Thanx for the help.
Brian
SuEllyn & Brian McCabe
Old 02-14-2011, 12:00 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
Brian, You're on to something there...I usually tell my RV battery customers, "Use it or lose it!"....
If your batteries are maintained properly, the number of 'cycles' or discharge/recharge's are then the limiting factors...
Usually, well maintained batteries should retain usable life for at least 4-6 years...unfortunately, many RV'ers neglect their batteries during storage, etc., and so only get about 3 years (or less) useful life...use em' or lose em'...
You can have a battery specialist shop use a load tester on your batteries to get an idea of their 'status'...however, you will usually be tipped off it's time to change batteries when it's noticeable that your 12 volt stuff won't run as long as before - IE; diminished capacity...
Other than the above, it's really hard to make an exact prediction as to when they will give up the ship...
Being 5 years old, and if you are embarking an extended trip soon, it might well be worth it to change them out now. You can then shop around for what you need, and not be stuck on the road for some high priced alternative....
As for engine 'starting' batteries, I tell customers to run em' till you notice a slower starting response in the morning, after the battery has set idle overnight - If it sounds like it's starting slower, or 'labored', it's time to have the battery load tested, to see if it's time to replace, which it usually is 95% of the time, after those 'symptoms'!
Ray & Pat; Morada, CA
Old 02-14-2011, 12:32 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Five years is a long time.
I have developed a habit of replacing batteries in cars, trucks, etc. every four years even if they appear to be in good condition. The inconvenience and cost of having them fail at an awkward moment when it is not feasible to comparison shop is too great, especially in Minnesota, where failures usually occur during severe winter weather.
If you look at the cost per year or even per five year cycle you don't really save much money by trying to get one more year out of the batteries.
In a trailer it might be a big deal or might not. A fact to consider is that not all failures are gradual.
Old 02-14-2011, 12:55 PM   #4
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Battery Life
My theory is to not replace stuff unless it shows signs of being on its last leg, or if I am upgrading to something better.
As mentioned above, there usually are some signs from the battery of age. Less juice over time, and harder and longer to charge.
If you SG test it on a regular basis and record the results in your log, you will know when the time is up, and you can start searching for the best replacement at the best price.
Where I live, there is little price competition on batteries, so I plan my buying with my off Island trips.
Theory does not always work, but you have to try.
How far you can make something last also depends on what you have for backup systems.
Dave
Old 02-14-2011, 01:05 PM   #5
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
One factor is how the batteries were treated while on a dealer lot. Were they allowed to discharge too much? Were they overcharged?
I think our trailer was only on the lot about 4 months, but knowing what we learned about the dealer after we bought our Safari, I assume they may have abused batteries.
After 3 years of use (about 7 months each year) they seem not to be holding a charge quite as well, but they test ok with a cheap tester. I am conflicted. I want them to die so I can get better batteries that work better with our solar system and have more capacity than the cheapo OEM batteries. I don't want to have to buy new batteries.
Gene
Old 02-14-2011, 01:16 PM   #6
moosetags's Avatar
Lucy languished on the dealer's lot for 16 months. The early FB's were not a good seller. When we bought Lucy new in June of 2006, the dealer put in brand new fresh Interstate batteries (SRM 24/550CCA/690MCA) when she was delivered to us.
Brian
Old 02-14-2011, 01:31 PM   #7
_
brian...
IF you've been regularly but LIGHTLY using this set, they could last a long time...
and if they are typically REcharged from a 70% or higher LOW point...
just keep on using them.
a simple test is furnace use (which is a bit of challenge in flo')
unplug the stream and set the furnace at about 20 degrees above interior temps...
then let the furnace cycle for 24 hours, check the battery level then run another 24 hours.
for folks that regularly use the furnace 2 days of use will deplete 2 grp 27s down to the 50% range (+/- 5%)
using actual voltage and furnace cycle times (with the known blower amps) can make this a reasonably accurate test.
_________
i once used a deep cycle battery on a 'stream for 12 years, yes 12 years.
and right now i've got a 9 year old german battery in an automobile,
and it still starts on the first tick (even at minus 10 morning temps) without hesitation.
this car sits UNdriven for months at a time, with a constant alarm load on the battery...
in other words the WORST possible abuse and it's still going at 9 years.
might replace it this spring, maybe.
the oem batteries in the 05 diesel truck (both of them) are also still going strong at 6 years ...
and the 2 agms in the 34 ftr are 6 years old this week, and still in daily use.
_____
so yes most folks may kill and replace every 3 years, but not all of us have that experience.
cheers
2air'
Old 02-18-2011, 11:56 AM   #8
1978 29' Ambassador
Beaverton , Oregon
Battery test readout - Feedback please!
Yesterday I took my trailer batteries to my mechanic to check on their status (Sears Marine/RV). These were purchased 7/2004 just after I bought my trailer ('78 Ambassador). I keep them charged in my garage on a 900 m/A automatic charger when not on the road.
He used a Snap-on battery/load tester and both came up as "good" after a 2 tier load test. The reading on the second one I got as a printed readout (as follows) battery size (670 CCA), available amps (764 CCA), rated capacity % (114%), Initial volts (13.23 V), Final volts (12.36 v) Impedance (4.18).
Anyone have any thoughts as to how these numbers stand up to a similar "new" replacement (lead/acid) battery?
Gary
GLMALM is offline   Reply With Quote
Old 02-18-2011, 02:07 PM   #9
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Thanx for the help.
Brian
Brian,
Other than just seat of the pants, they seem to be doing OK (that's what really counts anyway), the only good way to test them is under load over time. This is done with fairly expensive equipment. If you really want to know, take them somewhere and have it done. My advice would be to use them until they no longer meet your use requirements. I typically get 7-10 years out of batteries with decent care.
Regards,
Ken
Old 02-19-2011, 05:04 PM   #10
Master of Universe
Gene's Avatar
I'm sort of repeating myself, but… Besides whether the batteries are done with, another factor is getting better batteries for boondocking. The OEM ones are cheap and don't have the capacity needed for boondocking for very long especially if you have to use the furnace. I understand there are better batteries for use with a solar panel.
So although ours are holding up, I'm thinking of getting better ones. This will mean I have to run the generator less often when boondocking. I hate listening to them at campgrounds and I think that being a good neighbor means buying better batteries this spring. This will be part of our constant upgrades to the trailer—I'll be installing self adjusting brakes too.
Gene
Old 02-23-2011, 02:54 PM   #11
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Ours went t__s up at almost exactly three years. SG measurement confirmed it. I just attended a battery seminar at the Florida State Rally. The rep there from Exide said if you keep them on a battery tender or plug in no less than once a month, they should last until the advertised expiration date. He also recommended going to AGM batteries, but wait a couple of years for the price to come down.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 03-22-2017, 07:26 PM   #12
1967 26' Overlander
Eugene , Oregon
Battery shelf life
We have a chance to buy a battery that's been sitting on a shelf (never used) in an auto parts store for a year, at a really good price. ($40)
Good idea? Bad idea? Any advice would be appreciated!
stephiejo is offline   Reply With Quote
Old 03-22-2017, 08:31 PM   #13
lewster's Avatar
Naples, FL , Hood River, OR
VERY BAD IDEA!!!!!
Any battery other than lithiums will lose a substantial portion of their capacity due to self-discharge over time due to internal resistance. Liquid cells will lose charge much faster than AGM batteries du to their higher resistance. If these batteries have been without a charge for 12 months, there is an excellent chance that the plates have sulfated as a result of not having the charge maintained. Sulfation is many times not reversible and drastically reduces the original capacities of any lead acid battery.
Even at $40........... you would be throwing your money down the drain.
Just my professional opinion....of course!!
Old 03-23-2017, 08:38 AM   #14
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
You have landed on one of the challenges of lead acid batteries. You question of testing is a good one. The available energy is based on the plate surface area. Older batteries have less area and hence provide less energy even though the older battery will charge and display the correct voltages.
Not to make your head hurt but the following is how the test is done:
A capacity test takes a setup where a typical load is applied and the delivered current and voltage versus time is collect. The average current times the average voltage times the number of hours will become the energy capacity of the battery. For Amp Hours take the average current times the hours.
sgschwend is offline   Reply With Quote
looking for info on solar battery charging Globie64 Generators & Solar Power 11 02-21-2011 11:03 AM
Battery lost a cell. Desulfating or refurbishment possible? Keyair Batteries, Univolts, Converters & Inverters 57 02-14-2011 11:26 AM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 08:52 PM
Radio on house battery michalakes Electrical - Systems, Generators, Batteries & Solar 1 01-05-2011 02:07 AM
