Old 09-09-2013, 08:27 AM   #1
2013 23' International
madison , Wisconsin
battery tenders over winter time
This winter we're planning to store the Stream in a "self store" facility. The rent includes an AC outlet that I plan on using to keep the batteries (there are 2) charged and not frozen during the cold Wisconsin winter. Questions: 1) do I need to isolate the batteries and use a separate charger for each? and 2) What battery tender do you recommend? Don't really need a high output battery charger, just a 1-2 A trickle charge with multi-stage control.
thanks
jim1949 is offline   Reply With Quote
Old 09-09-2013, 08:35 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I like the Battery Tenders. One for each battery.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-09-2013, 10:11 AM   #3
withidl's Avatar
2002 31' Classic
Houston , Texas
I use a "Schumacher Battery Companion" purchased from Sears several years ago for ~$20 and keep all of my vehicle batteries charged with it. The following data is from it's labeling:
  • Model SE1562A 6V - 12V
  • 1.5 Amp Slow Charge
  • Output: 6/12V at 1.5A DC
  • Fully Automatic Battery Charger / Maintainer with Float Mode Monitoring
I have plugged the coach converter into a power strip which has an on/off switch which I turn off when the Schumacher is charging. I connect the Schumacher positive clamp to the 12 volt breaker box positive bus bar, and the negative clamp to an improvised ground within that same breaker box. The Schumacher AC plug uses an AC outlet within the coach, which is always plugged into AC ground power.
I leave the 12 volt master disconnect switch ON so that I have lights in the coach (which resides in my back yard).
The Schumacher charges both AGM batteries simultaneously, and keeps them totally topped off.
withidl is offline   Reply With Quote
Old 09-09-2013, 11:01 AM   #4
Enthusiastic New AS'r
3campers's Avatar
1985 31' Limited
Glenville , New York
Images: 18
I pull mine and keep them hooked up in my garage. I have a Deltran Battery Tender with 2 bank charger system...it has connections for two batteries...works just fine...
http://www.amazon.com/Battery-Tender...battery+tender
1985 31' Limited
2003 GMC Sierra HD SLT 4x4
3campers is offline   Reply With Quote
Old 09-09-2013, 12:23 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Battery Tender 022-0165-DL-WH 12-Volt 2-Bank Battery Management System : Amazon.com : Automotive
I also remove for Winter storage...they go to the "charge room" in the basement.
ID:	195328   Click image for larger version
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 09-09-2013, 01:05 PM   #6
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
You only need one battery tender. Make a jumper cable that connect the terminals together just like in the trailer and one tender will tend to both batteries at the same time.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 09-09-2013, 02:30 PM   #7
Skater's Avatar
1995 30' Excella
Bowie , Maryland
If you have a 3 stage converter, you can just let that take care of the batteries.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 09-09-2013, 02:38 PM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
My Battery Minder came with a short cable that I leave connected to the batteries in the trailer. This cable then plugs into the Battery Minder when in storage. So the batteries are being charged and on float without the Safari's converter plugged in. Works well for me. I'm still on my original 2007 batteries though they are starting to get a little weak. Of course they could fail any day, but I won't worry about it until spring.
Old 09-09-2013, 02:54 PM   #9
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
A new converter would cost you more than a tender, but is probably a better long term solution. I had a Deltran on my Corvette and the Deltran just failed after 11 months. I have an Xtreme on order. CTEK is well regarded. I do not know what to trust in the RV world, my boat charger/inverter worked fine for decades so I would think a good 3 stage converter is the answer, with your AS plugged in while in storage.
Larry
Larry
lsbrodsky is offline   Reply With Quote
Old 09-09-2013, 03:01 PM   #10
Thumbs up
In my experience batteries do not appreciate being left alone with an unfamiliar, possibly fickle device.
They really need the human attention.
PFC
"Tahawus"
RLC
John Prine
Old 09-09-2013, 05:48 PM   #11
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Kind of like infants, eh? Well, at least you don't have to change a battery's diaper!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-09-2013, 05:57 PM   #12
Wayne&Sam's Avatar
Images: 21
I do check on my trailer and charger every couple of weeks.
Old 09-09-2013, 06:06 PM   #13
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I don't usually bother on the camper or motorcycle, but I have to on the lawn mower or the battery will only last 2 years.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-09-2013, 06:24 PM   #14
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Thanks. Ordered mine and should have it soon. I REALLY wish I could find internal storage for the Tin Goat. At least I can have some peace of mind with the batteries. :-)
