Old 06-02-2015, 11:23 AM   #1
Battery Tender Question
Have read through several threads but not finding a direct answer to a question - if using a battery tender for long-term storage, am interested in your thoughts on whether a 5 amp tender is needed or if a 1.25 amp unit would be adequate - batteries are in original configuration i.e. positive to positive and negative to negative - any thoughts / suggestions are welcome!
3eb25 is offline   Reply With Quote
Old 06-02-2015, 11:24 AM   #2
dznf0g's Avatar
Oswego , Illinois
I prefer a BatteryMinder brand and the smaller one is adequate for long term maintenance.
-Rich-
Old 06-02-2015, 11:42 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
DITTO!
Their model 12248 is especially good, as it it adjustable for type of battery AND had a temperature sensor.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 06-02-2015, 11:58 AM   #4
chilipepper's Avatar
1971 27' Overlander
Dickinson , North Dakota
I also have the BatteryMinder 12248 and am really pleased with its performance.
Ryan Jilek
WBCCI 7165 | TAC ND-3
Ms. Streamy - 1971 Overlander Restoration Blog
chilipepper is offline   Reply With Quote
Old 06-02-2015, 01:52 PM   #5
1981 31' Excella II
New Market , Alabama
I have several of the small Battery Tenders that I use on motorcycles but they will keep a full size battery charged as well. You don't need 5A if all you are doing is floating a battery that has not load on it. There are small current draws on a normal system unless the battery is physically unhooked from the trailer. If the battery is sitting on the floor of the garage the small tender will work. If you are going to keep it connected to the trailer electrical system and larger one would be better.
Perry
Old 06-03-2015, 06:23 PM   #6
Thanks to all for the super quick responses - really good information - did some research last night and today and the 12248 is on order!
Old 06-24-2015, 08:10 PM   #7
F150 4X4 ProPride
mycloud9's Avatar
2015 30' Flying Cloud
Kingwood , Texas
Would Lew or anyone comment on the VMAX BC1215 Battery Charger?
BC1215A 12V 15A 7 Stage Smart Battery Charger / Maintainer
mycloud9 is offline   Reply With Quote
Old 06-24-2015, 08:18 PM   #8
lewster's Avatar
Looked at the specs. It has no adjustment for type of battery. I would get the BatteryMinder 12248, as it does enable you to select the battery type, has temperature compensation and is adjustable for 2,4 or 8 amp charging.
Old 06-24-2015, 09:15 PM   #9
F150 4X4 ProPride
mycloud9's Avatar
Kingwood , Texas
Thanks, Looking at BatteryMINDer now. My current Charger is a 30 year old Craftsman!
Battery Tender Solar Question mrpettit Electrical - Systems, Generators, Batteries & Solar 11 12-25-2014 10:35 AM
Battery Tender and Univolt? AldeanFan Batteries, Univolts, Converters & Inverters 8 08-31-2011 11:16 AM
Battery Tender Hookup for two parallel batteries Tater Batteries, Univolts, Converters & Inverters 0 11-29-2010 04:28 PM
Deltran Battery Tender Jean Wisjink Batteries, Univolts, Converters & Inverters 0 10-13-2010 05:57 PM
