Old 08-27-2009, 10:58 PM   #1
2008 25' Safari FB SE
Delta , British Columbia
battery switch off - fridge running
Even though the battery disconnect switch is in the off position, and there is no shore power, and the fridge is turned off, the fridge has been running ( it's cold ) and the batteries are now dead. We are not able to establish if we have done something wrong. Thanks from Joyce and Jim
Joyce and Jim is offline   Reply With Quote
Old 08-28-2009, 07:23 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
If the fridge is turned off, but it's still running, something wrong with the fridge. Off should be off.
Once you have the batteries charged again, disconnect shore power and move the battery disconnect switch to the off position. Now, go check your CO or Propane monitor, which should run off your 12 volts. If it's still on, then the disconnect switch is not removing all battery power from the circuits inside the trailer. You can also check for 12 volts with the interior lights, radio, etc. Nothing should work if the battery is truly disconnected by the switch.
Chris
Old 08-28-2009, 07:34 AM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
On the newer trailers the battery disconnect switch kills everything except the propane detector. While your fridge will run on gas, it needs some power from the battery to keep the "brains" working.
If you are sure you had the disconnect fully in the off position, you may have some problem with the switch or how the fridge was wired. Once you get the battery back in charge you might try to turn the swtich off and recheck things again. If the fridge stays on, try some of the interior lights and see if they work. You will find out quickly if it's a switch issue or fridge wiring.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-28-2009, 08:33 AM   #4
Master of Universe
Gene's Avatar
Grand Junction , Colorado
Does the read out on the fridge that tells the temperature work? If so, the batteries may not be totally dead. If not, it's possible that the fridge will just keep getting colder and colder because there is no brain to tell it to shut off to maintain a constant temp. Or, of course, the wiring may be screwed up.
Gene
Old 08-28-2009, 08:35 AM   #5
Minno's Avatar
1972 31' Sovereign
Jack - thanks for the clarification on the propane detector. I didn't realize that was the case now.
Chris
2003 Dometic fridge won't stop running J Goertzen Refrigerators 0 08-29-2008 08:49 AM
only partial DC when running off battery jeff&jess Batteries, Univolts, Converters & Inverters 8 03-06-2007 07:30 PM
Running Univolt W/ Out Battery andoboba Batteries, Univolts, Converters & Inverters 1 10-12-2004 09:38 AM
Battery Running Down... streamlean Airstream Motorhome Forums 23 01-13-2004 11:13 PM
Running the fridge while towing? andyfuson General Motorhome Topics 15 09-20-2003 12:15 AM
