Old 07-08-2011, 02:45 PM   #1
1963tradewin's Avatar
1963 24' Tradewind
, , Minnesota
Battery Switch Installation
I have a Perko 1, 2, all and off switch I would like to connect to my batterys just not sure on how to do it. On the back of the perko I have a 1 connection a 2 and a common. I am not sure which connections to use. Diagram 1 shows 1 wire going thru, and what I would like to do except with 2 batterys, and instead of kill switch put the Perko there. Anyone know how to hook this up? Thanks for the help!
Name:	7 Way Trailer Plug Hookup.jpg
Psalm 67:7
1963tradewin is offline   Reply With Quote
Old 07-08-2011, 03:09 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
1 battery hot to #1 other battery to #2 the 3rd terminal is your hot coming out of the switch.Just remember to charge the switch needs to be to all. Dave
easyride is offline   Reply With Quote
Old 07-09-2011, 11:38 AM   #3
George
2007 25' Classic
Calgary , Alberta
Perko wiring
Not sure it helps, but attached my wiring diagram. I'm just installing a Perko switch, it shows how the Perko switch goes into the system.
As the last post says, batteries go to posts 1 and 2. Then install a heavy wire (minimum 6 gauge) from Common to wherever your two batteries used to connect (in my case, a positive bus bar).
My reason for installation is to ensure the last remaining phantom draws are eliminated. When I turn the Airstream kill switch off, there are still a few small phantom battery drains (primarily the LP Gas detector), that are big enough to put a serious dent in the battery over a month.
George
George
2007 Classic 25'/ 2013 Cayenne GTS/ 2015 GMC 2500HD Denali
gwmc is offline   Reply With Quote
Clipper, Dometic Refrigerator, Fridge Lamp Switch masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 01-05-2013 11:14 AM
Only one battery charging heslinhotel Batteries, Univolts, Converters & Inverters 11 02-21-2011 08:49 PM
Battery switch behind the sofa LawChick Batteries, Univolts, Converters & Inverters 9 01-13-2011 08:52 PM
