02-18-2014, 02:51 PM
2024 23' Flying Cloud
San Antonio
Battery Switch Inside "On" or "Off"?
Ok, I have read the manual front to back, and am still confused. Our rig is a 2014 Sport 22FB. By the front bed is the battery disconnect switch. When the trailer is in storage, I turn that switch "off" to prevent any phantom drains. When we take the Airstream out, I turn the switch "on", and leave it on for the duration of the trip. We are not boondocking, but are connected to shore power while camping. Two questions:
1) Can the battery be overcharged by being connected to shore power with the battery switch in the "on " position for several days? What if I am connected to shore power, and leave the 7 pin plugged into the TV?
2) Under what circumstances, if any, would I want/need to turn the battery switch "off" while connected to shore power?
Thanks in advance.
02-18-2014, 03:38 PM
Alamo Heights
With the converter that Airstream supplies, you'll eventually overcharge the battery if you leave it on shore power all the time. If it's just on shore power when you're actually traveling and camping in it, that'll take a long time but it will likely shorten the life of your battery somewhat.
Whether the converter backfeeds your TV through the umbilical depends on your TV. Some have a diode that prevents it, some disconnect the charge line when the ignition is switched off, some would allow it. You're not likely to get enough current feeding back to harm your TV's battery even over weeks of having it plugged in, and any way the only time you're likely to be both on shore power and plugged into the TV is on an overnight stop where you don't unhitch.
I can't remember if the new ones isolate the battery from being charged in "store." I think they do, and in any event it would be easy to check. The tricky thing about the store/use solenoid is that the light is always on when you're plugged in, so you need to unplug to be 100% sure of the state of the solenoid. Unplug, switch to "store", check the battery voltage (at the battery posts directly), plug in, recheck the voltage. If it's the same (12.7-ish volts) then they're isolated when in Store, if the voltage jumps up then they're being charged in Store.
So, if they're isolated, you could switch to Store after a few days at a campsite when you're sure the batteries are fully charged. I think the propane detector is wired right to the batteries, so it'll eventually drain them and you'll need to charge again.
Someone with a trailer new enough to have that store/use switch will be along presently to give a more definitive answer. If I want to disconnect my battery I have to open the battery box, old-school like.
— David
02-18-2014, 03:53 PM
2006 19' Safari SE
Tucson
You are correct to switch to "store" while your rig is in storage and disconnected from shore power, for exactly the reasons you describe ... to isolate the battery from phantom draws. For long, extended times of storage some folks physically disconnect the batteries and put them on a battery minder to maintain them over the long haul, but for intermittent periods of storage you should be fine.
Likewise, you are correct in switching to "use" while camping in your rig...even if you are plugged into shore power. (In fact, if I am not mistaken, being plugged in overrides the disconnect ... at last that is the case with ours.) It is highly unlikely that your batteries will be overcharged when plugged in while you are camping in it because there are draws on the battery all the whole time ... lights, frig, propane detector, furnace, etc.
We store our rig at home, plugged into 30-amp continuously. We do not switch to "store" during that time, however we leave the frig on, use the lights, water pump, furnace, AC, TV and radio from time to time — we pretty much doing everything one would do while camping, but sleeping in it — so in our case, there are constant draws during our version of "storage" ... so far our batteries have, therefore, never overcharge.
We typically disconnect from the tow vehicle when we stop, even if we are just there for the night ... just to make sure.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
02-18-2014, 06:30 PM
1974 Argosy 20
Kooskia
, Idaho
On my 2014 FC 20' when in the store mode, the battery is disconnected from the loads in the trailer except:
1.The propane detector which is always on and takes 6 to 8 mA constantly. It is not shut down by the Store/Use switch.
2.The optional inverter which is wired directly to the batteries and does not go through the Store disconnect. So, you could turn the inverter on by accident and run the batteries down even in the Store mode. My inverter has a large standby current of 1.75 amps, when doing nothing at all so that discharge is a potential for killing the batteries easily.
When in Store mode the converter/charger is disconnected from the batteries but will supply 12 volts for the lights and other 12 volt items in the rig. But it will not charge the batteries, or allow them to be discharged, other than the two items mentioned above.
I have a modern 3 stage converter/charger in my rig now, not the original Paralax which came with it from the factory. So, I have no problems leaving my Store switch on all the time. With the original Paralax I would probably limit the time that the rig was plugged in and the store switch on to maybe a week if the unit is unused. That would minimize the possibility of a battery overcharge situation. But it is not something you need to be paranoid about. Just don't leave the rig plugged in for months with the original Paralax converter/charger.
In looking at the 12 volt electrical diagram, it appears that the Tow Vehicle charge line is directly connected to the Airstream batteries and is not disconnected by the Store mode switch. So, if the Tow Vehicle is left plugged into the Airstream and does not have a relay in the tow vehicle itself, it will be charged by the converter/charger if the Store mode switch is left in the Use position, but not if it is in the Store position, same as the Airstream batteries. Some tow vehicles have an isolation relay, some do not. My 2012 Jeep Grand Cherokee does not. I believe Ford's do. No idea about GM vehicles.
The Use/Store switch is a relatively complicated thing to wrap your mind around, so don't stress if you don't understand it at first. It may take a while, I know it did with me and I am pretty electrically savy.
02-18-2014, 09:31 PM
2012 25' Flying Cloud
Battle Lake
When stored we select "STORE" to isolate everything but the propane detector from the batteries.
When plugged into shore power we select "STORE" to isolate the batteries from being repeatedly overcharged and ruined by the Parallax converter.
We have a solar system to keep the batteries up.
The only time we select the "USE" position is when towing to keep the refrigerator running on propane, and when dry camping to power the 12 volt equipment.
Doug and Cheryl
02-19-2014, 03:51 AM
Lin
, Ne
Why doesn't your trailers electronics automatically charge your batteries?
02-19-2014, 05:38 AM
1995 30' Excella
Bowie
, Maryland
They do, but Airstream uses cheap single stage chargers and they overcharge the batteries.
We've replaced ours with a three stage charger, and now I never turn the switch to store.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
02-19-2014, 06:11 AM
Lin
, Ne
Don't the single stage chargers have voltage regulators? My 1985 Avion with original electrics doesn't overcharge my batteries.
02-20-2014, 07:50 AM
Battle Lake
There are many accounts of the stock Airstream converter overcharging and ruining batteries, other than that it works fine. (It ruined the batteries in two years on our 2007 Airstream before we bought this new trailer with the solar system.)
So by using the "STORE" battery position whenever plugged into external power, we never allow the converter to charge our batteries. Only the solar system does, or the truck when towing.
Doug and Cheryl
07-05-2016, 09:29 AM
2015 23' Flying Cloud
2023 Interstate 19
Scottsdale
I dug this thread up to figure out my store/use switch on our 2015 FC23D.
Right not we have the AS in our storage location plugged into 110. I have the multistage Intel-Power 4600 Converter/Charger.
The red light is constantly on but you can here the relay if you push use or store. I have been pushing store when we leave for the day.
What position should we leave the switch in while connected to 110?
07-31-2016, 02:25 PM
2015 25' FB Flying Cloud
Alexandria
, Virginia
Fellow Streamers....following and searching threads closely on the battery/converter/disconnect switch issue. I have a 25ft. FC 2015. Both batteries were replaced today, only 18 months old and I'm a maintenance junky. Try to do everything right. Latest situation and experiments with a followup question. I have been hooked up to shore power for the most part since mid-June. As you guys have suggested, I occasionally leave it in the store position...more often than not while on SP. One battery had been sucking up water. Just had it checked at Advance Auto and it is fried. I had been checking the water every couple of days..
Prior to testing the battery, I had noticed last night that the converter fan never turned off. This morning, I turned off SP, and used the inverter for the TV to test how long it would take to drain the batteries. They went from 12.7 volts to 10.5 in roughly 2 hours. Which led to testing the one battery that had been sucking up water. My guess is the converter never shut down because the fried battery would not accept a charge. I plan on upgrading my converter when I get home from this trip.
Now, here is what I don't get. With both batteries removed and on SP, the so called 12 volt appliances (fridge) were working. Lights worked. Only the LP monitor did not. Question: Is the converter still charging the fridge and the lights? Again, I had removed both batteries waiting to install the new ones. This leads me to the conclusion that while on SP, you really don't need the batteries at all with the exception of LP monitor?
I do understand the disconnect switch function. The other oddity was that with the batteries removed, and again, on SP, the Sea Level Monitor still showed the "battery" at 13.7 volts even thought I had removed the batteries?! (Switch was in "store") I know I'm jumping around with several issues, but they seem connected. Any help appreciated.
Patti
Patti
07-31-2016, 03:03 PM
2007 22' International CCD
Corona
Propane detector is wired to the battery side of the disconnect relay. With an open store/use relay and dead or disconnected batteries the propane detector would get no power from the convertor.
It's the way AS wired it....and the subject of some controversy.
Walnut Creek
Oh, what fun to learn how the systems on out coaches work.
First.....make sure the water in the battery bank is full. Only takes a minute to check and distilled water (not drinking water) is inexpensive.
Second....you can.....not get all the parasitic loads disconnected.....well you can, but it's a fuse here and a cable there and well - install a disconnect on the main coach feed from the battery and include an in-line fuse. Look at Lewster's posts. He provided a suggestion and explained the need for a fuse.
Third....as a general practice you won't kill the batteries, if you do not switch to store when on shore power at an overnight stop. See step first above.
Fourth.....as a general rule, you will kill the batteries if you store the trailer on shore power. The batteries need to be charged with a source that monitors their condition and only provides power when the charge drops. Too much charge, too little charge or no charge is a problem. The standard AS converter is single stage and charges at too high a rate.
Fifth......the parasitic draw will kill a battery bank in two to four weeks. Do not assume that because the trailer is in storage it will be OK. Driving the voltage of a wet cell battery below 12-12.2Vs is not helpful to battery life.
Sixth.....do not get all bent. A new battery bank is +/-$200 for a Walmart solution or you can fight with Interstate for replacements. However, it is not the end of the world if your batteries get killed. It is going to be an inconvenience and a bit of care is a good idea.
Seventh.....There are a lot of folks who know everything about the electrical system of an Airstream. They are the source of the above info. I just stole it from reading their posts. You can too.
PS - yes, the converter provides the trailer with 12 volts when on shore power with the battery bank removed. Do not believe the tongue jack would have power and it does the converter no good to not have the bank in the circuit. Edit - see post above on the LPG detector as well.
Good luck with the coach. Travel safe. Pat
12-07-2016, 03:38 PM
2019 30' Classic
Canfield
, Ohio
Well, I learned my lesson. I had my rig plugged in for 3 months and completely fried one battery. It was down a quart!.
Interstate didn't care. Replaced the 4-month-old battery and said Merry Christmas. The other battery has tested fine.
What three stage converter / charger would you recommend for a 2017 AS?
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
12-08-2016, 07:28 PM
2000 31' Excella
Ontario
, Canada
Good thread. Thanks to all for your valuable insight..
When in Florida last year, one of the 2 coach batteries exploded in the night. I assumed it was the heat and overcharging. I was connected to shore power and had the battery switch to "on". Just might leave battery cut off switch off for most of the time. But then I'll have to do something for the propane detector.
Woody
12-08-2016, 07:57 PM
2015 27' Flying Cloud
Newberg
, Oregon
Woody
Wow! I thought I had problems after my batteries died after only 13 months. I'm glad I replaced the original converter with a multistage one.
Mike
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Land Yacht battery control center
speedy45 |
Electrical - Systems, Generators, Batteries & Solar |
2 |
11-19-2011 11:12 AM |
Battery Tender and Univolt?
AldeanFan |
Batteries, Univolts, Converters & Inverters |
8 |
08-31-2011 11:16 AM |
BATTERY ON/OFF SWITCH - What Do I Do?
Fly at Night |
36 |
08-30-2011 08:24 PM |
Battery Bank Upgrade
Gwuk |
5 |
03-24-2011 08:18 AM |
Only one battery charging
heslinhotel |
11 |
02-21-2011 08:49 PM |
