Old 07-11-2009, 02:53 PM   #1
Archersfin's Avatar
1986 34' Excella
Conroe , Texas
Battery switch HELP?
There is a battery switch behind the Goucho in front of my 85 Excella, just above the Converter. It says ON OFF. What does this switch do?
I am still trying to learn about this Camping thing without a tent. Getting to old for them. I have posted pics of the Excella under the intorduction web page titled 85 Excella 34'.
Thanks for any help given.
Al
Archersfin is offline   Reply With Quote
Old 07-11-2009, 03:26 PM   #2
SteveH's Avatar
Common Sense , Texas
The switch should be a main battery disconnect. Disconnects the battery or batteries from the rest of the 12 volt system.
Old 07-11-2009, 05:16 PM   #3
dstalzer's Avatar
2005 25' Classic
Not sure if it isolates the batteries, but I know none of the lights work in the AS if the switch is turned to off.
Dennis
dstalzer is offline   Reply With Quote
Old 07-11-2009, 06:08 PM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
It should disconnect everything except the electric jack if you have one.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-12-2009, 04:17 AM   #5
Archersfin's Avatar
1986 34' Excella
Conroe , Texas
Thanks for the replys. I will try the lights in the off position and see what happens. I do have an electric jack.
Old 07-14-2009, 08:35 PM   #6
2002 31' Classic
Wyoming , Michigan
On/Off switch
I have a dual battery setup on the 2002 Classic, and when I went to hook the battery up I got a spark when putting down the Neg cable. ( I put the positive down first). this didn't seem right and I checked the on/off switch and it was off. I have the thing torn apart and do see some other leads off the main terminal. Thanks for the tip on the electric jack. Anyone know if anything else it hooked up before the on/off switch?? The drawing isn't very clear.
Max Bauer is offline   Reply With Quote
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 9 04-13-2015 05:39 PM
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 6 02-08-2013 06:34 PM
House battery master switch Taxman Land Yacht/Legacy Motorhomes 22 05-01-2009 07:41 AM
Breakaway Switch and Battery brud Brakes & Brake Controllers 16 07-27-2006 08:19 PM
New battery switch - 2003 Classic Pahaska 2001 - 2005 Classic 15 05-29-2005 08:28 PM
