Old 01-15-2018, 09:41 AM   #1
2015 25' Flying Cloud
Oro Valley , Arizona
Battery storage box too small
I have a 2015 FC 25RB. I am considering the purchase of two Trojan 6v batteries to replace the stock Interstates. It looks like the Trojans are a couple of inches taller and wouldn’t fit under the lid. Has anyone else encountered this issue and what was your remedy? I would prefer the batteries remain outside due to a shortage of storage space inside. Thanks for your help.
zonastream is offline   Reply With Quote
Old 01-15-2018, 09:48 AM   #2
2013 25' International
Boise , Idaho
Box extensions
Yep, this is a well-known issue people experience. MANY good threads if you query the search. Most people raise the height at the top of the box, but you'll see some people who drop the bottom when clearance is an issue. Newer trailers have taller boxes.
-Adam
afk314 is offline   Reply With Quote
Old 01-16-2018, 08:42 AM   #3
2013 25' Flying Cloud
Middleton , Idaho
I did what you want to do. I used a box extender from Vinnie's Northbay Airstream. Simple and worked well.
https://www.facebook.com/pg/VinniesN...04542062955224
Trailbob is offline   Reply With Quote
Old 01-16-2018, 09:11 PM   #4
Thanks for your responses. I really like the look of Vinnie’s product. It should be perfect for my needs.
Old 01-16-2018, 09:43 PM   #5
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
The 2027 AS’s have a battery box that is just about 1/16th of an inch shy of 12” deep. Also, after trying to track down a supplier of Trojan batteries that didn’t have a $160 shipping charge racked on, I ran across Batteries Plus 6 volt batteries. The Duracell 6v ultra golf cart batteries are 64 lbs. and they get great reviews. One year warranty but I suppose if they last the year and you take care of them, they will do all right. $114 plus a 10% discount and at the same ah rating, I’m going for them.
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
***Support Airstream Forum***
turk123 is offline   Reply With Quote
Old 01-16-2018, 09:44 PM   #6
AirDreamer
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Same amp hr rating as t105 re Trojans. Pick them up at a local store (Batteries Plus) and no shipping!
Old 01-16-2018, 09:48 PM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I added two inches to the top of my box using aluminum square channel. Used self taping screws. Certainly not as pretty as a professionally made extension but it still gets positive comments and safely does the job.
MICHAEL
Old 01-16-2018, 10:48 PM   #8
1959 22' Caravanner
Some town , Tennessee
You do know you can buy surplus military boxes for dirt cheap check on eBay.
Twinkie59 is offline   Reply With Quote
Old 01-17-2018, 01:05 AM   #9
2018 25' Flying Cloud
Portland , Oregon
I used two of the 6v Duracell deep cycle flooded batteries in my last RV. They were fine when the draw was below a 100 amps or so but, like most flooded batteries, weren’t happy about going much higher without significant voltage drop. My Magnsine inverter would often try to pull more than that when running the microwave, hair drier, etc. If you have that kind of application I’d bite the bullet and go AGM or Lithium.
daleyocum is offline   Reply With Quote
Either the AS is too big or the TV is too small Jim Lee On The Road... 18 12-07-2014 09:21 AM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 12:01 PM
Trailer too Large? TV too small? pixiehat Tow Vehicles 45 03-13-2009 10:36 AM
