Old 07-30-2015, 08:23 PM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
Battery Size
Does a 25' come standard with group 24 or group 27 batteries.
Thanks!
Old 07-30-2015, 08:38 PM   #2
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Generally speaking, group 24 lead/acid wet cell are standard. Many upgrade to group 27 AGM or 6 volt batteries for the increased storage capacity.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 07-30-2015, 09:59 PM   #3
txdxrider's Avatar
1976 31' Excella 500
Providence Village , Texas
We have a 27 in our 76...
Let's party with Pirates and Ninja's.....
txdxrider is offline   Reply With Quote
Old 07-31-2015, 05:28 AM   #4
Hans627's Avatar
Tavares , Florida
Thanks. My AS is a 2009 25' FB Int. Will group 27 fit in the standard battery box? I like the idea of the 6 volt but the added weight is an issue for me as I'm maxed out of payload. The size is an issue as well but I understand the box can be modified to accept them.
BTW I like the caption under you name.
Old 07-31-2015, 07:55 AM   #5
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
Once I put the Solar panels on w/Blue Sky Controller, I immediately upgraded to 2 #27 group for the additional storage. Works well!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 07-31-2015, 08:00 AM   #6
TinShack's Avatar
2005 28' Safari S/O
The 6 volt batteries are taller so the top of the battery box will need to be raised. I have a friend who did this by fabricating a collar that's the same dimensions as the existing box, and remounting the lid to the collar.
I have two Lifeline G27 AGM batteries in the A-frame box, but I had to modify the box slightly to get them in. The box size on my 2005 is fine, but it has a lip around the top that faces inward and makes it impossible to get the batteries in. I had to cut off part of the lip on one side next to the latch...enough to drop in one battery at a time. Drop one in slide it over, then drop in the second one.
Spent many days in Hanover, my folks lived in Hampstead just down the road. Half the shoes in my closet are from the Hanover Shoe Outlet there in the Center Square.
Steve
Old 08-01-2015, 03:58 PM   #7
fotoman1527's Avatar
2012 27' Flying Cloud
Miami , Florida
I'm having a hard time finding a vendor to extend the battery box on my FC 27 from the bottom; I don't want to elongate the box on top because I don't think the storage door under the bed would open. I'm thinking about just putting in the largest batteries I can find without changing the compartment. Boondocking use with solar and perhaps a Honda 2000i converted to propane are under consideration for a charging option. Has someone gone this route? What are the largest batteries you've found that fit without modifying the box? Or would you keep going until I can find someone to enlarge the box and use golf cart batteries, such as the Trojan-105RE, which the manufacturer says are ideal for the task. T-105-RE | Trojan Battery Company THANKS!
fotoman1527 is offline   Reply With Quote
Awning size; wheel lug nut size jaygoree 2011 - 2015 International 0 02-19-2015 04:18 PM
What size TT have the same size awnings LI Pets Awnings 11 07-19-2014 01:04 PM
Plug size and ball size for '66 Safari 22'? Jezibels Hitches, Couplers & Balls 3 08-13-2009 06:59 AM
Twin Size Size Over59 Upholstery, Blinds, Walls & Interior Finishes 5 08-20-2004 10:18 AM
battery size? larry smith Electrical - Systems, Generators, Batteries & Solar 2 08-12-2002 08:29 AM
