Old 01-15-2012, 06:17 PM   #1
AirHog's Avatar
2005 34' Classic
N Smithfield , Rhode Island
Images: 21
Question Battery/Shore Power
Battery.
Our unit is stored indoor for the winter (unheated large garage/barn). I took the batteries out and have them hooked to a battery tender. My friend advised me that I should not hook up up to shore power if there is no batteries in the unit. It may damage the electrical system in the unit. Is there any truth to the statement ? I do like to check the trailer every two weeks or so and do need the lights or turn the heaters etc.
Any opinion/advise will be helpful.
Best,
Titu
Titu & Gail
2005 34' Classic-Mercury (Goddess of Travel)
2016 GMC Sierra Denali 2500HD Diesel
BRN-2905
NEAC of Region 1
AirHog is offline   Reply With Quote
Old 01-15-2012, 06:58 PM   #2
Naples , Florida
Depends.....................on the type of converter that you have. I know for a fact that the IOTAs and Progressive Dynamics do not need a battery to operate the trailer's 12VDC system. If you have the OEM converter..........maybe not.
lewster
Old 01-15-2012, 07:18 PM   #3
I've had an OEM univolt on shore power for almost a year and no problems. Just be sure the terminals don't touch. When my batteries cooked, I took them out of circuit.
I'll make investment in AGM's when I decide to travel again.
0557 is offline   Reply With Quote
Old 01-15-2012, 07:25 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Not having the batteries in the circuit will cause the output voltage of the converter to have more ac voltage noise on it. Some electronic devices might not work properly with this poor a power input, but likely would not be damaged. TV's and radios would have static. The batteries act like giant capacitors and soak up the irregularities.
Old 01-15-2012, 08:13 PM   #5
Naples , Florida
That is true of the older style converters, but modern electronic switch mode converters do not exhibit AC or DC 'ripple effect' problems. IOTA specifies that their units can be operated without batteries, and I have installed several in units where the battery was bad and not replaced. These units are tied to concrete pads and do not move, so the presence of a battery is not required. No problems have been noticed with any of their DC components for several years.
OTOH, any trailer that is taken on the road MUST have a battery installed to operate the break-a-way safety switch in the trailer's braking system.
lewster
Old 01-15-2012, 08:52 PM   #6
AirHog's Avatar
2005 34' Classic
Images: 21
Ours is a 2005 34 Classic with OEM everything. So will it harm anything with no batteries on board, if I occasionally plug in AC ? Thanks.
Titu & Gail
BRN-2905
NEAC of Region 1
Old 01-15-2012, 09:59 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
Lewster is correct. The converter used in the 2005 Classic does not require a battery to be present to work properly.
Old 01-15-2012, 10:07 PM   #8
AirHog's Avatar
2005 34' Classic
Images: 21
Many thanks to all.
Titu
Titu & Gail
BRN-2905
NEAC of Region 1
battery
Power Loss & Pets Inside? Frank&Mike The Pet Forum 67 07-27-2013 08:57 AM
Half of the outlets have no power VeggieBullet Electrical - Systems, Generators, Batteries & Solar 23 01-22-2012 08:08 PM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
Newbie has power questions Czechitout Electrical - Systems, Generators, Batteries & Solar 2 08-07-2011 04:20 PM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
