Old 12-13-2007, 05:47 PM   #1
2007 25' Safari FB SE
Truckee , California
Smile Battery Security
Hi, just purchased a 2007 25' SafariFB SE, and was wondering what folks do to prevent battery theft . Unfortunately i have to leave my trailer in a storage away from my home, but can't help that. Could pull the batteries each time, maybe thats the best thing to do, but when boondocking and leaving the rig without the TV around need a way to keep honest folks honest.
Fred
p.s. saw some great solutions for the propane tanks, but nothing so far on batteries.
flyfishfred is offline   Reply With Quote
Old 12-13-2007, 05:58 PM   #2
uwe
418
uwe's Avatar
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Fred
How about a swiveling latch, riteted to the battery box? Then a padlock can be used to secure the top of the battery box.
You might be able to drill 2 holes in such a way that you can loop a padlock through the holes, and don't even need a latch.
The third option would be to modify the current lid catch to accept a locking device, as is used on compartment doors.
Uwe
www.area63productions.com
Old 12-13-2007, 06:34 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
No real heavy mods needed. When I was at Jackson Center, I simply bought a not as deep lock assembly, similar to the ones that are on the fresh tank fill cover (just not as deep). I am sure most locksmith shops would carry the same type of lock tumblers. To size it, simply take the standard non-locking latch assembly off, bring it with you and you can size it up really easy. You can even get them keyed the same or differently.
I think they cost something like $2 or $3 each. Put one on the fridge outer access door and one on the battery box. Took all of maybe 3-5 minutes to remove both standard factory latches and replace both with keyed access.
At some point I plan on placing a switch in the battery box to shut off the power jack.
The locks have been on for a bit over two years and work great. You'd be hard pressed to not think it was a factory install....now watch, the factory sees this post and starts doing this just like some of the backspashes and the SE edition of the base Safari....maybe I should work for Airstream!
Old 12-13-2007, 07:36 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
I use 2 locks on my batteries as they are Lifelines and over $300 each.
I use a lock on the cover like Twink does...mine has a cylindrical key. Then when you open the cover, there is another lock (the same one I use to secure my LP tanks) attached to the hold-down bolt for the batteries.
Someone would really need to work hard to get those puppies!
Old 12-13-2007, 07:42 PM   #5
New Borockton , Alabama
Images: 21
My recommendation is while in storage, pull 'em especially if you don't have power to keep them charged.
When boondocking, chance it but place a label on the cover that explains they are insured by the NRA.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 12-13-2007, 09:10 PM   #6
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
SilverGate's thread shows the lock he switched out on his battery box...looks pretty spiffy...haven't done that myself yet, but I intend to! His thread is http://www.airforums.com/forums/f396...-29471-23.html
starting with post #321...
TB
TB & Greg and Abbey Schnauzer
#3954
Old 12-13-2007, 09:47 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, locking the battery hold down like Lew did would be the best; A lock on the cover would just look good, I could easily bend the cover open with my bare hands. [ A five year old could get it open] Also with the combination or key lock faceing upward, water would get in and damage the lock unless you cover them with something.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-14-2007, 06:31 AM   #8
Aluminut
2004 25' Safari
. , Illinois
Below is a picture of what I use on the cars, truck, boat and Airstream when they sit for extended periods outdoors. It's what VW ships with their new cars. A word of caution though, the new ones shipped from VW connect to the OBD2 connection of the vehicle, the older ones connect to the cig lighter power port. You can do a search on eBay for these using the search VW solar...you can typically get these for about 15 bucks.
The Suburban in particular has a significant parasitic draw with all the computers and such for seats, PCM, stereo, etc. The battery battery typically goes dead after about a month....until I got a few of these. The Suburban has about 3 or 4 cig power outlets. I just place these in it and it keeps the battery with power.
The Airstream has 2 of these types of 12v outlets and one can easily purchase a 2-4 adapter extension to expand the number of connections and 12v cord extensions. I keep about 2 running in the Airstream when it sitting outside when I boondock. My main issue is with these now is that it's fairly difficult when you have indoor storage, but then again, if you have indoor, the need for locks is diminished as is the power issue since most places have at least 1 120v outlet.
Old 12-14-2007, 06:52 AM   #9
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Aircraft cable
When I had the 22' with the exposed battery box, I made up a length of 1/8" aircraft cable with thimbles at the ends to reach around the battery box and the frame underneath. I attached the cable to the battery box with two footman's loops, pop-riveted to the sides of the box with big washers inside so that the cable could not be slipped off the box. I then connected the thimbled ends with a sturdy padlock. Aircraft cable is hard to cut; I usually cut it with a hammer and sharp chisel on an anvil.
Here is the photo that I posted years ago.
John W. Irwin
WBCCI #9632
Old 12-14-2007, 07:07 AM   #10
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I think I missed something. I have locking battery boxes in the '77 Overlander I have no propane cover. I have a chain thru both bottles and a padlock,that will slow them down. What does everyone else use to secure propane bottles?
Mikethefixit is offline   Reply With Quote
Old 12-14-2007, 07:09 AM   #11
CanoeStream's Avatar
St. Cloud , Minnesota
This thread has been referenced above: http://www.airforums.com/forums/f287...ock-36720.html
5 meter Langford Nahanni
Old 12-19-2007, 09:06 PM   #12
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Just this weekend, while camping, replaced the swivel latch on the battery box of our 06 19' Bambi with the same type of lock, but keyed...it was $3.99 at Ace Hardware... (Just remove the original and take it with you to the store so you can hopefully avoid the mandatory 3 trips to the hardware store per project by getting the right one the first time.) Ours took a 1/4" shaft. It came with two different lengths of latch tabs that do the actual locking under the inner edge of the battery box, but we ended up using the latch tab from the original swivel lock. I am going to get 2 more of the same locks and replace the swivel locks on the 2 vent doors on the outside behind the frig, too...and get them all keyed the same. Lord knows I don't need another key on my keychain! Now to lock the propane tanks!
TB
#3954
Old 12-19-2007, 10:12 PM   #13
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Aha, you guys explained why my Excella has different keys on the battery doors and the refrig door than the main key. Somebody switched out an original keyless latch for me years ago maybe.
NevadaGeo is offline   Reply With Quote
Old 12-20-2007, 06:41 AM   #14
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Propane security
Heavy Security cable and combination lock.
Michelle TAC MT-0
Sarah, Snowball
Security Jenturnr Towing, Tow Vehicles & Hitches 19 12-01-2005 09:05 AM
Security ardenrj Towing, Tow Vehicles & Hitches 28 07-30-2005 10:42 AM
Security luckydc Our Community 26 06-06-2004 01:50 PM
Towing security for doors markdoane Exterior Storage Compartments & Access Doors 4 11-20-2003 04:39 PM
Security... canny_banjo_man Our Community 14 06-18-2003 03:34 PM
