Old 03-15-2019, 08:38 AM   #1
2008 27' Classic FB
Green Cove Springs , Florida
Battery removal 2008 Classic
Sorry if this post has already been addressed, but my batteries are located in individual compartments accessed through locked doors in the front of my AS Classic. They appear to have been wedged in without much clearance either on top, bottom or sides. Is there a trick to getting the batteries out of their compartments? All I want to do is check water levels...
tujeeze is offline   Reply With Quote
Old 03-15-2019, 08:55 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
This is what I did to get the Lifeline AGM's out of our Classic, over that stupid lip at the door hinge.👍 Pick up on the strap & Pull.🤓 (the new Lithiums are lighter/easier).
ID:	335733   Click image for larger version
ID:	335735   Click image for larger version
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 03-15-2019, 12:39 PM   #3
2007 27' Classic FB
Ridgefield , Washington
When I pull my batteries, getting over the lip is the only issue. I usually lift it using the edge of the plastic carry strap. I am wondering if your batteries are too big for the compartment. You should be able to get the cable nearest the door off and on without difficulty.
John
Woosch is offline   Reply With Quote
Old 03-15-2019, 05:05 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I use straps similar to Robert Cross. Before straps, I used a wooden paint stirring stick/paddle to create a ramp to slide the battery up and over that door lip. A putty knife will work also.
Alan
Old 03-15-2019, 05:14 PM   #5
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I've done similar things to those shown above - straps, pull-tabs or something similar. However, you don't have that now so a little TLC with some wooden sticks as mentioned above. It's a real pain if you don't have a strap in place. Once you get these out I know you'll add a strap or something for next time.
By the way, be very careful that you don't touch the positive terminal to the chassis of the trailer while you're pulling the batteries out. I use a piece of thin cardboard, cut from a soda box or something similar, to ensure I don't short out the positive terminal.
Lucius and Danielle
1992 29' Excella Classic
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 03-16-2019, 10:47 AM   #6
2007 27' Classic FB
Otis Orchards , Washington
What a great idea!
Wstewart is offline   Reply With Quote
Old 03-16-2019, 11:12 AM   #7
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I also have an ‘08 27FB Classic and as we have found, there’s little wiggle room for those batteries. One has to assume the lip it sits behind was to keep the battery from shifting forward under hard braking or an accident that could through the + terminal against the grounded body. I’ve been using a very wide blade putty knife as a ramp once I encourage the front end of the battery upward. I really do like the idea of the web strap and will adopt that the next time I pull them out to check the levels. Important point was made to shield the + post with an insulator. Also remember that the batteries are in parallel and so if you take one battery out and disconnect the cables, the free red cable is still hot if the other battery is still connected.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 03-16-2019, 11:25 AM   #8
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I put the battery in with the negative terminal on the outside. Pull the battery partially out, disconnect the negative terminal, then no risk of shorting the positive terminal to chassis. Reverse the process when installing the batteries. Connect positive, put battery most of the way in, connect negative, and slide it the rest of the way in.
I also use the end of the carry strap to lift and pull the batteries out.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 03-17-2019, 08:09 AM   #9
harryk's Avatar
2005 31' Classic
Venice , Florida
Use a short crowbar to lift slightly on the bottom and pull on the strap...as soon as it starts coming over the lip, lose the crowbar...
harryk is offline   Reply With Quote
Old 03-17-2019, 08:19 AM   #10
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
On my 86, there are two drain slots on the bottom of the compartment that I have a stick that is about 1/2" square and 12" long. By sticking it in the slot and pushing down it raises the battery up and forward over the lip.
Streamracer is offline   Reply With Quote
Rivet Removal Tool OR Blind Rivet Removal T mkamanu General Interior Topics 3 10-12-2015 07:29 PM
Removal of 2nd row seats on a 2008? TimCar Sprinter and B-van Forum 10 12-10-2014 02:27 PM
AC removal before interior wall/shell removal? TexasAir67 Exterior Restoration Forum 1 07-25-2013 07:58 AM
2008 31' Classic / 2008 Silverado 2500 4x4 duramax ddarr2 Member Introductions 19 03-09-2010 12:14 PM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 01:00 PM
