Old 08-27-2008, 04:01 PM   #15
Carson City , Nevada
Wahoonc - the reason I moved the batteries forward is to minimum flex and loading at the rear of the trailer (each of the four 6V batts weighs 60 lbs.) and because there is no good place to put them elsewhere. Over the ax;es seemed like the right thing to do.I am having to modify the twin bed construction to accommodate them, but I plan on replacing all the interior cabinets and stuff next year anyway.
M
Mike S is offline   Reply With Quote
Old 08-31-2008, 11:47 AM   #16
1980 28' Excella II
Schuyler , Virginia
i have 29' 1980 excella, on the owner manual it show 2 battteries on the diagram. is the second battery optional, i could not find it on my trailer.
boonskyler is offline   Reply With Quote
Old 08-31-2008, 12:23 PM   #17
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by Mike S View Post
Here is the preliminary wiring diagram for the battery banks.
That's a lot of battery. I assume you do a lot of boondocking for extended periods? I am just curious why you decided to go for 4 batteries and the battery isolation switch.
Old 09-02-2008, 10:02 PM   #18
I usually stay out for weeks at a time. I do have a Hinda generator, but feel that more is better, especially since I plan on a 120 AC/12 DC Norcold fridge/freezer that will provide proper cooling whilr driving and camping.
The reason for the isolation switch is that AGM batteries charge up quickly and, if deeply discharged, may pull a lot of amperage from the 60 Amp charger on the Xantrex converter. By switching between banks I can:
- Charge one bank (190 Amp Hours) at a time, and not create any potential for a problem,
- Have a reserve if I lose a battery cell (or the entire battery), since this would drop voltage to below 12V (remember I am using 2 6V batts per bank)
Maybe it is un-necessary, but I have worked on boats and vehicles using two battery banks, and lke the reserve concept.
A/C relocation Cochese Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-14-2007 03:30 PM
Furnace vent relocation. Safari Tim Furnaces, Heaters, Fireplaces & Air Conditioning 0 01-22-2005 07:37 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
Converter relocation FrankR Batteries, Univolts, Converters & Inverters 0 07-31-2002 08:30 AM
