Old 09-02-2015, 06:26 AM   #1
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Battery Recommendations?
I recently acquired a FREE Grape Solar 400 watt off grid system consisting of 4 each 100 watt panels, a Xantrex C-Series 35 amp controller, and a Xantrex PROwatt 200 watt sine wave inverter. I thought I'd hook this rig up to my 23 ft. Safari.
Unfortunately there is only enough room on top for 2 (100 watt each) panels, so I'm going to work with that...
Considering the equipment (specifically the controller) would you guys mind making some battery recommendations? Benefits of golf cart batteries? Lithium vs. wet or gel? I don't mind spending a few more bucks for smaller size and weight.
Any recommendations would be greatly appreciated.
Also, a source for tilting rooftop mounting brackets for the panels would be greatly appreciated as well.
bvcg1 is offline   Reply With Quote
Old 09-02-2015, 07:19 AM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We are putting at least four and perhaps five 100 watt solar panels from AM Solar on the roof of the 2015 23D. We installed a very low vent for the plumbing and replaced the stock Winegard batwing type antenna with the Winegard Rayzar automatic HD TV antenna. This allowed for the narrow solar panels to be either side of the exhaust fans, skylight and air conditioner.
These folks have a great solar primer you can read on line. We have purchased all the components for two system from these folks:
Welcome to AM Solar_Your RV Solar Specialists since 1987
Note that all solar panel "ratings" are under laboratory conditions. Top quality solar panels can see about 75% of the rated number or 75 watts from a 100 watt panel on a bright day with the sun directly overhead.
We removed the two stock Interstate lead acid batteries and are replacing them with one AM Solar 300 amp-hour lithium iron phosphate battery that weighs 84 pounds (about 8 pounds less than the two stock batteries) and has a 14.5" x 11.25" foot print and needs 11.25 of height space when installed. This battery will provide between 80 and 85% of it's rated power, or around 250 amp-hours. Lifeline GSM batteries will tolerate about a 50% power draw and the stock lead acid will tolerate a much lower percentage than the Lifeline batteries.
The battery is mounted just forward of the street side wheel well under the dinette with the Magnum MSH-3012 hybrid charger/inverter/converter mounted adjacent. The Blue Sky solar charger control box is mounted behind the microwave above the refrigerator. The BlueSky control head and the Magnum control head are mounted on a hickory panel below the television.
As a comparison in terms of weight, for our Classic, we replaced four 300 amp-hour Lifelines (the four weighed 372 pounds) with their custom stainless steel battery enclosure with a single 600 amp-hour lithium iron phosphate battery (weighs 168 pounds with four 3.2Vdc modules of 42 pounds each) that is now under the sofa. We were able to shed over 175 pounds of tongue weight down to just under 1,200 pounds. Our usable power went from 300 amp hours with the Lifeline batteries to over 500 amp hours with the lithium iron phosphate battery.
My experience with our 2013 25FB with a dealer installed 155 watt solar panel, Zamp controller and using the factory solar pre-wiring with #10 wire was it could not recharge the two stock Interstate batteries to full capacity after the furnace ran most of the night. The days were cloudless and bright sunshine. We had to use a 2,000 watt generator to get the batteries fully charged for the next night furnace use.
Old 09-02-2015, 09:03 AM   #3
1974 Argosy 20
Kooskia , Idaho
I have two Grape Solar 100 watt panels on my '14 FC 20'. I use a Blue Sky MPPT charge controller but am very familiar with the Xantrex C 35 you have and it is a good unit. I have installed at least 6 in other installations.
I use two 6 volt golf cart batteries in series as my battery bank. See post #18, this thread, for photos of raising the battery box cover to accommodate them.
http://www.airforums.com/forums/f449...-124829-2.html
I have a Tri Metric battery monitoring system. I have been boondocking now for 14 days in Forest Service Campgrounds as wild fires have forced me out of my home. All power has come from the solar system, other than some charge from the tow vehicle when I had to move from one FS campground to another due to smoke. My Tri metric meter has shown the Lowest charge in the morning, after using the furnace at night, with 42 F temps, to be 78%.
You will do fine with 200 watts of panels and two golf cart batteries in your rig. Add a third panel if you can, but it will not be necessary.
Old 09-02-2015, 12:47 PM   #4
bvcg1's Avatar
1971 23' Safari
San Antonio , Texas
Thanks! What is the model number or the Tri Metric? Also I was thinking of using the Trojan AGM 100 amp-hour battery. Thoughts? Do you know if it is okay to have the same battery being charged by both my shore power charger AND the solar controller?
new battery recommendations? Lumatic Batteries, Univolts, Converters & Inverters 13 12-24-2008 12:18 PM
Classic MOHO Replacement Battery recommendations zamboni Classic Motorhomes 10 10-30-2007 06:28 PM
To battery or not to battery 29348 Batteries, Univolts, Converters & Inverters 4 07-16-2006 02:02 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
