Bingo. I am totally FINE with wiring of all kinds. My concern was getting into a lot of mechanical crawling around or going underneath, or heavy work. Wiring is my thang. Thank you so much for the info.
It isn't bad. mostly huddling on the floor. The hardest part to me was as mentioned, after feeding the original wiring harness through the holes in the converter housing, getting it to reach far enough to have some play to work with. everything else was just transferring wires and labeling the new wiring Legend (what's what). What is really nice is that they now have the wizard built into the unit so you can manually override a charge cycle.
