Old 01-31-2015, 04:52 PM   #1
Horsey5's Avatar
2014 23' International
Sandy , Utah
Battery quick disconnects best one to get
I have my airstream in indoor storage and plan on taking in out and about at least once a month. I don't want to take the batteries out so would like to get a quick disconnect switch installed. It has to be easy to use and hopefully something my son can install. He works on his own cars so should be up to the challenge. I am looking for suggestions on the best one to use. I like the look of the ones that have a turn dial. Thanks!!
Horsey5 is offline   Reply With Quote
Old 01-31-2015, 06:04 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
HELLA MARINE Windlass Circuit On/Off Switch | West Marine
Inexpensive and easy to install.
MICHAEL
Old 01-31-2015, 06:20 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
PERKO
Old 01-31-2015, 07:37 PM   #4
1974 Argosy 20
Kooskia , Idaho
Perko
Old 01-31-2015, 07:40 PM   #5
Horsey5's Avatar
Sandy , Utah
Battery disconnect
Which perko do you get. The one for 2 batteries or the one that just turns off and on?
Old 01-31-2015, 08:00 PM   #6
Mineral Bluff , Georgia
I saw this one at Harbor Freight, and it looked fine:
Heavy Duty Battery Cutoff Switch
Price is right, anyway!
FastEddieB is offline   Reply With Quote
Old 01-31-2015, 08:05 PM   #7
1974 Argosy 20
Kooskia , Idaho
Either can be wired to do what you want. I happened to use the two battery one so I could disconnect my inverter separately from the remainder of the system.
Old 02-01-2015, 02:55 PM   #8
TetonStreamer
Teton Stream's Avatar
2017 23' Flying Cloud
Wilson , Wyoming
Why not use the Battery Switch that comes with your 23' International? In the "Store" position isn't the battery box disconnected from the trailer? (Or is the propane sniffer still activated?!?)
Teton Streamer - in The Toaster
Wilson, WY 83014
Teton Stream is offline   Reply With Quote
Old 02-01-2015, 06:07 PM   #9
George
2007 25' Classic
Calgary , Alberta
I installed this Perko model PERKO Inc. - Catalog - Battery Switches - Medium Duty Battery Selector Switch [8501]
I like the ability to switch to one battery, in case I want to take one out of service.
The Store switch doesn't eliminate all loads, at least the propane detector is still on. I found my power draw still big enough to kill the battery in a few weeks.
George
2007 Classic 25'/ 2013 Cayenne GTS/ 2015 GMC 2500HD Denali
gwmc is offline   Reply With Quote
Old 02-01-2015, 06:44 PM   #10
Horsey5's Avatar
Sandy , Utah
Even when you use the store switch there are a few things propane detector, co detector that stay on and seem to drain the battery. I am not an expert but I have heard that disconnecting the batteries for short term storage may solve this problem.
Old 02-01-2015, 07:25 PM   #11
xo1rider's Avatar
2012 27' FB International
Fremont , California
I got this Amazon.com: Battery Terminal Master Disconnect With Green Knob 12V Or 24V Car Truck Boat: Automotive
Sweet and simple, cheap and does the job. I like it and in a way I find it a minor theft deterrent as the electric jack won't work when it's in use.
"The bad news: there is no key to the universe.
The good news: it was never locked."
Swami Beyondananda
http://polakoff.com/RamblinRose/
Our travel log
xo1rider is offline   Reply With Quote
Old 02-01-2015, 07:48 PM   #12
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
If one uses the battery disconnect will the solar panels continue to keep the batteries charged up? Or if plugged in will the batteries maintain their charge? Not good to let batteries discharge.
TinCan
graysailor is offline   Reply With Quote
Best Go-To quick recipes when camping kswelsh Fun & Games 4 01-26-2014 08:13 AM
Hope I get a reply quick! AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-07-2011 07:43 AM
Another Zip Dee Question--just a quick one! Becky B. Awnings 11 07-12-2010 08:36 PM
Electrical disconnects davidz71 Electrical - Systems, Generators, Batteries & Solar 3 02-18-2004 08:34 PM
waterhose quick disconnects John Fresh Water Systems 3 04-19-2002 06:58 PM
