Old 08-20-2011, 07:00 AM   #1
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
Battery Question
We were getting ready to go camping this weekend and went to get the camper and the jack wouldnt work (electric). So John plugged up the camper to raise the jack and we have no power at all. We went and bought a new battery at Walmart. It was a marine battery but it will not fit in the hole, it is about an inch too tall. What kinds of batteries have any of you bought besides the expensive gel batteries that will fit inside the box? It is a 2000 and the batteries are behind the propane tanks. Not a lot of room back there. Any ideas of why we have no power even when plugged up? We have not had any trouble from the camper since we got it. Have been camping almost every weekend since we bought it. Thanks for any help you can give us.
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 08-20-2011, 07:04 AM   #2
Retired.
. , At Large
I worked on a SOB that had a 40 amp fuse going tot he positive lead on the battery. The fuse had blown, which meant that the converter couldn't charge it, and nothing could get power from it. Also check the grounds, and make sure they are good.
Old 08-20-2011, 07:09 AM   #3
"Cloudsplitter"
ST
A group 27 size should fit.
As Terry mentioned.
Check those breakers first.
Good Luck..
Old 08-21-2011, 03:15 PM   #4
2000 25' Excella
Thanks for the help!! Terry, it was the two fuses on top of the converter that were blown. We replaced them and all is well, that was simple enough!
John & Tammy Adams
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 02:33 PM
Battery Issues imuir Batteries, Univolts, Converters & Inverters 29 08-08-2011 07:27 PM
Battery Maintenance Question pappy19 Batteries, Univolts, Converters & Inverters 5 03-31-2011 09:14 PM
