Old 10-29-2006, 11:17 AM   #1
jemison , Alabama
battery question
I went to walmart today to buy a battery and came home empty-handed. They basicaly have the eveready marine batteries. They are deep cycly and I think wet celled. I was going to get the 24 model. One said starting and one didn't. I'm guessing I don't need the starting feature? Also, they don't say 12 volt like all the car batteries. Am I to assume they are 12 volt? One more thing, what kind of thgings dod you have to do to care for a wet cycle battery? Last thing, what guage cable should I get to go from a PD 60 amp converter to the battery. Thanks out there!
rama777 is offline   Reply With Quote
Old 10-29-2006, 11:42 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You want the deep cycle, sometimes called trolling, battery. If you get a group 24, it is a 12 volt battery. If you can get it to fit, you might consider the group 27 battery. It is a little longer, and has more reserve capacity (it will run things longer). You take care of a battery like that the way you should take care of any automotive battery, that is, check the electrolyte (acid) level in the battery monthly to keep it from going dry, and clean corrosion off the terminals when it appears.
10 gauge wire should be sufficient for a charge line from your converter.
Old 10-29-2006, 12:50 PM   #3
jemison , Alabama
I am going to be living in my airstream and I will be plugged in all the time. Will my 60 amp converter charge the battery faster than I am using it? Thanks for helping.
Old 10-29-2006, 01:52 PM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I am going to be living in my airstream and I will be plugged in all the time. Will my 60 amp converter charge the battery faster than I am using it? ...
Battery charging is not an issue if you are plugged in all the time. In fact, if you have a modern-day converter, many vendors claim the battery is not even necessary with their converter. While believable, I personally have not tested the claim.
Tom
Old 10-29-2006, 01:52 PM   #5
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
The Deep Cycle MArine type battery is the way to go, unless you want to spend several times as much for glass mat or gel cell batteries. I'd agree that "Group 27" has more reserve capacity than Group 24, and your battery tray should be large enough for the larger battery. Terry has explained maintenance, which involves keeping fluid in it by adding water to each cell when it drops below the level tabs in the battery..
As for usage, once battery is charged, you should not be able to draw down power beyond capacity of charger.. Some of the power from charger goes direct to 12V loads inside trailer (all lighting, refrigerator controls and electronics, furnace contraols and fan, and vents). Those loads are pretty small, and most trailers will run for a weekend or more without any charger. The Univolt or other chargers will keep battery charged and provide all the additional 12V power needed when you are parked and plugged in...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 10-29-2006, 02:01 PM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If you have the original UniVolt charger, I would be more concerned with over charging the battery...
Richard
Old 10-29-2006, 02:52 PM   #7
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
The PD 60A charger will be sufficient to power the lights and fans inside the trailer,with some power to spare. You do not need a battery with this charger.
I found, however, that the system seems more stable, and the charger ran quieter when a battery was connected to it. My system also employs the charge wizard.
I use 6ga battery cable for my connections from battery to charger, and from charger to the fuse panel. My converter has a fuse for the system, otherwise you should put a 40A or 60A fuse between the battery and the fuse panel.
Uwe
www.area63productions.com
Old 10-29-2006, 03:41 PM   #8
Images: 59
You may also want to put in a disconnect switch. About $15.
Old 10-29-2006, 04:08 PM   #9
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Does anybody know if two group 27 batteries will fit in the A-frame mounted battery box on late model Airstreams?
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 10-29-2006, 10:41 PM   #10
jemison , Alabama
Cool. Will my converter run the lights, fans, and the original a/c unit? Thanks for the info.
Old 10-30-2006, 07:47 AM   #11
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
lights and fans: yes.
air conditioner: no. that runs directly from the 110vAC...just like any of the AC outlets in the camper.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 10-30-2006, 04:06 PM   #12
jemison , Alabama
really? It seems to be a part of the 12 volt schematic in my manual anyway.
Old 10-30-2006, 04:33 PM   #13
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
What Chuck said - it's definitely not part of the 12V system, and has nothing to do with the charging and light circuit.
Uwe
Old 10-30-2006, 05:07 PM   #14
TomW's Avatar
1967 26' Overlander
Me three
What uwe said - I mean what Chuck said -
Tom
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 05:49 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
