Old 11-08-2004, 01:55 PM   #1
luckydc's Avatar
Richmond , Virginia
Battery Quandary-Help!
Help! I thought I knew a bit about batteries, but after reading numerous old threads, I still don't know anything.
I have been keeping my trailer plugged into the house. Is this not good for the batteries? Been reading about batteries over charging and even boiling. The batteries in my trailer have not experienced any water loss.
I thought I could leave the trailer plugged in over the winter and that the batteries would be fine. Guess that is not right? Any suggestions on what trickle charger to get?
Paul
WBCCI #2468
2006 Ford F-150 Lariart 4X4
2004 19' Bambi Safari LS
luckydc is offline   Reply With Quote
Old 11-08-2004, 02:09 PM   #2
luckydc's Avatar
Richmond , Virginia
I just looked at my batteries again and it looks like the water has gone down some. It use to be right at the bottom of the fill holes. That is, level with the fill hole. Now it is just below the fill holes.
Distilled water, right?
Oh, I guess I better unplug the trailer from the house.
Paul
WBCCI #2468
Old 11-08-2004, 02:51 PM   #3
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
I chucked the old Univolt for a modern switched mode charger with a brain. It allows you to keep your trailer plugged in year around. It also monitors and conditions your battery. Using it will make your battery last longer.
Here is a web site that has a lot of battery information, it should give you a start on what you need to know. http://www.uuhome.de/william.darden/
GOOD lUCK
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 11-08-2004, 03:44 PM   #4
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
As your AS is a 2004, I would recommend going back to AS.
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
I need battery basics Stefrobrts Batteries, Univolts, Converters & Inverters 9 05-10-2004 09:08 AM
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
