Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 08-30-2007, 08:27 AM   #1
dreamin
dreamin's Avatar
Profile:  Salisbury , Maryland
Battery Problems
2003 Airstream Classic
I have had to fill the batteries with water twice this summer and have heard a hissing noise in the vicinity of the inverter. Today my wife called and said there was a "chemical" smell in the trailer. She unplugged the shore power and opened the battery compartments to let them vent. She said the batteries look bloated. I am assuming that the inverter is not shutting off, but charging the batts continuously. Does this sound right?
Also, what does the battery cut off switch do exactly?
Can we camp without batteries?
Can you haul without batteries?
We are supposed to leave tomorrow morning for a 4 hour drive and then to camp at a place with AC.
Thanks for your help!
Terri and Chuck
2003 Classic 30' SO
2004 GMC 2500HD 4X4 D/A Ext. Cab
dreamin is offline   Reply With Quote
Old 08-30-2007, 08:35 AM   #2
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Helena , Montana
A converter charges your batteries 110VAC to 12VDC well ok its 14. An Inverter make 110 from 12VDC.
THe converter is over charging the batteries or your have a short in one of them. Check the voltage with the the shore power and batteries connected. should be 13.8 to 14.2. If it is higher then the converter /charger is the problem. If it is ok you have a problem with one or both batteries.
I suggest you do not tow with out batteries. They are your breakaway energy source.
IF the converter is out of wack then it can damage your Refrigerator. CHeck the voltage.
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 08-30-2007, 08:39 AM   #3
The Flintstones
The Flintstones's Avatar
Profile:  1970 27' Overlander
Houston , Texas
Sounds like your "Univolt" is cooking your battery, mine does the same thing. I have been charging my battery with another charger and leaving my switch off when plugged into shore power to prevent charging from unit untill I can purchase a new one.
I have an O2 sensor inside that was beeping because of the gasses from the battery so I would not use yours untill you can fix and also install a sensor. Be carefull!
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 08-30-2007, 09:15 AM   #4
gotohatteras
gotohatteras's Avatar
Profile:  2006 23' Safari SE
Avon , North Carolina
Get a "Charge Wizard"...costs about $50. Had one on our Lance truck camper, and it won't allow your batteries to be overcharged. Camping World has them. I'm putting one on our A/S ...asap! Can't believe they don't come with one.
DW always tells me to "take the high road"...
2006 23' Safari
2007 F350 Lariat Crew 4X4 PSD
AIR# 21875
WBCCI# 3778
Region 3, Unit 144 (Eastern North Carolina)
gotohatteras is offline   Reply With Quote
Old 08-30-2007, 08:11 PM   #5
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
If this is the Charge Wizard by Intellipower then he will need the 9100 series converter/charger as well. The newer Intellipower 9200 series converter/charger has the Charge Wizard built in.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
davidz71 is online now   Reply With Quote
Old 08-31-2007, 03:03 PM   #6
ROBERT CROSS
THE FRANTIC BANANA
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 31
Overcharging
Had a similar problem with our 2003 Classic. We have the parallax 7400 series converter/charger, turned out the batteries were sulfated,probably from being plugged into shore power at the dealer too long without checking water level. Although level was ok at delivery,they boiled dry after a week when we returned from our first camping trip. We still ck them once a week when plugged in, but haven't had a problem after replcement.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Battery Location uwe 1970-76 Tradewind 22 09-04-2003 07:44 PM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Auto Battery problems.... kzener40 Airstream Motorhome Forums 10 08-05-2002 06:37 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
