Old 11-02-2006, 12:21 PM   #1
kamo's Avatar
burbank , California
battery polarity
Ok, so I've got the battery for my '62 Bambi. Ready to hook it up, when I noticedthat the ground wire (hooked up to the trailer's body) is RED, which usually means '+'.
Ground is negative, right?
Just wanna make sure before I smoke something.
Kamo
kamo is offline   Reply With Quote
Old 11-02-2006, 12:43 PM   #2
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Kamo
Ground is Negative. Do not hook positive side of battery to chassis ground. "boatdoc"
boatdoc is offline   Reply With Quote
Old 11-02-2006, 01:00 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
red only means plus (+) in electronics, not in power electrics. It makes me crazy, too. Yes, ground is negative these days, has been since the mid-50s. Most stuff won't notice except your radio and, in a car, fuel guage.
Gee, where'd I put the keys to the Studebaker?
Zep
Old 11-02-2006, 05:14 PM   #4
kamo's Avatar
Good thing I asked.
I'll replace the red cable right away with a black one.
Old 11-03-2006, 04:06 AM   #5
boatdoc's Avatar
1973 Argosy 26
Arrow Battery polarity
Good thing I asked.
Hi kamo; In reality the color of insulation does not make any difference as long as it is of proper polarity. The standard code for 12V DC negative is black, and any other color coating just does not look right although it will work the same. Thanks "Boatdoc"
Old 11-03-2006, 04:20 PM   #6
kamo's Avatar
Thanks for the info, boatdoc. I just want to make sure it's black, so I (or someone else) won't hook up the battery in reverse.
The other positive wire is actually blue. So I'm replacing that with red.
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
Battery Slide Out niftypkg Electrical - Systems, Generators, Batteries & Solar 5 01-01-2003 03:41 PM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
