Old 01-05-2010, 08:58 PM   #1
Southern , California
Battery placement for '65 Caravel
Hi All,
I'm installing a new battery in my Caravel. It's a 12v Lifeline AGM 210 amp/hrs. The battery weights 135 lbs. I'm thinking about installing it inside the street side compartment underneath front gaucho. (please see the picture)
Will this battery placement make the trailer's street side off balance too much? Will it make the tongue weight too heavy?
Alternately, I can install it in the middle compartment underneath the side gaucho which will be almost on top and slightly forward of the axle but I will have to dismantle the gaucho's frame to be able to install this new big and heavy battery.
Thank you very much for all your comments and suggestions,
Suti
teeraniti is offline   Reply With Quote
Old 01-05-2010, 10:07 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Why so big?
I used the smaller Lifeline battery....plenty of Amp hours for the boondocking life....It fits perfectly in the side compartment.
Old 01-05-2010, 10:16 PM   #3
I'm planing for a long trip in the near future. and want to have at least 200 amp of battery power, just in case. Most places we want to go to don't have electrical hookup.
Old 01-05-2010, 10:33 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Seems like keeping it up close to the tongue would be the best idea. Wow, that's a heavy battery!
Stephanie
Old 01-06-2010, 02:29 AM   #5
65CV's Avatar
Western , Massachusetts
Lifeline location
Suti-
It's hard to tell exactly where you're locating the battery under the front gaucho. I've attached a picture of the framing from below the trailer. The part painted white here is the exposed part of the frame, as it enters the bellypan. Notice how there is a wide area that is unsupported in the center, but see how well supported it is outboard. Unfortunately, this will drive you to place the battery further to the street side so that it sits on the frame. Stated more simply: eyeball the frame from the tongue and try to locate the battery on that frame.
The other location you're considering is well supported. See post #15 of this thread: http://www.airforums.com/forums/f145...vel-45046.html Notice the two outriggers just forward of the wheel (the tongue of the trailer is to the top of that picture). If you locate it here, you'll want to orient the battery sideways so that it spans those two outriggers.
Weight distribution is key, of course. Have you considered weighing the trailer to see what your tongue weight is now? Our local scale will allow us a second weighing for a dollar. If you weigh the entire trailer, then hook up and weigh again with just the wheels on the scale, you can calculate the % of weight on the tongue. It should be 10-15%. If you are close to 15%, you probably want to locate the battery further back.
This is a heavy battery, and either location will affect side to side balance. You can also consider 2 6-volt batteries and locate them so that they balance well side-to-side. We used the Lifeline GPL-4C's and are very happy with them.
Also, you don't have the original axle, right??
John
65CV is offline   Reply With Quote
Old 01-06-2010, 05:49 AM   #6
1977 Argosy 24
Milltown , Wisconsin
Where ever you put it, do not vent it into the interior. Make sure it is in a compartment that is sealed from the interior and vented to the outside.
ventport is offline   Reply With Quote
Old 01-06-2010, 06:43 AM   #7
Thanks John and everyone. My trailer still has original axle but is getting a new one this week. I think I'll put it over the axle as it seems to be the best location. John, where do you put the two 4C batteries?
Old 01-16-2010, 08:10 PM   #8
_
increasing battery capacity...
2 grp 27 lifeline agms will provide basically the same amp/hour capacity as the big boy, grp 4 battery...
and can be place EVENLY across the front of the trailer, on the tongue OR under the gaucho...
the advantage of 2x12v over 2x6v is that EITHER battery can provide 12v should one fail...
the advantage over the big g4 is that IF you ever decide to add more capacity, that can be done with another g27.
in order to increase reserve with the larger grp 4, one would need to add another 135lb battery...
also lifting/moving the grp 27s is easier than the grp 4.
this is ALL inter related with this other thread...
http://www.airforums.com/forums/f464...vel-60291.html
cheers
2air'
Old 01-17-2010, 05:50 PM   #9
65CV's Avatar
Placement
Sorry -- I missed the question until tonight.
I placed them just aft of the wheelwells, slightly inboard to make sure they were right on the frame.
John
caravel
Generator Placement Ag&Au Generators & Solar Power 0 11-06-2009 01:08 PM
Battery Placement Retrofit Tom Bray Batteries, Univolts, Converters & Inverters 2 09-12-2007 07:11 PM
New speaker placement TomW General Interior Topics 13 04-22-2005 05:44 PM
Deadbolt placement? Gunnyusmc All Argosy Trailers 0 09-12-2003 06:10 AM
Extra Battery Placement JaceBeck 1997 - 1999 Safari 16 10-02-2002 01:03 PM
