Old 08-23-2004, 09:27 AM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
battery: phantom load, or normal discharge?
getting ready to go out dry-camping next weekend, so I was checking my battery yesterday. Voltage was down to 12.44. Trailer has been sitting for 2 weeks, not plugged in at all, not using anything since the last rally, where I was plugged into shore power for 3 straight days. as far as I can tell, the univolt works properly. I wouldn't think it would discharge that much in a couple of weeks. 2 things that I'm wondering:
1), I checked the water level, and it is high...possibly too high? water level appears to be up into the tubes.
2) my newer (<5 year old) fridge has been on the whole time, running on gas...wondering if these newer fridges are still using 12v for thermostat or other functions, even when set to "gas". (?).
I don't generally keep the trailer plugged in to a/c when not using it, (not anymore, anyway ), so as to avoid the dreaded univolt-overcharging syndrome.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-23-2004, 09:38 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
The easiest way to see if something is draining your battery is to make sure everything is off, then disconnect the positive lead from the battery, and put a 12 volt light bulb in series with the battery & the disconnected lead. The bulb should not glow. If it does, something is pulling current. How brightly it glows will determine if you have a problem.
Some of the electronics installed on everything (radio, fridge, etc.) may pull a tiny amount of current. However, I do not think any single one of the items would pull enough to illuminate the bulb.
Did you discover too much water in the cells before or after charging. I could see it being a little high after charging. Regardless, unless it was running out of the battery, I doubt the electrolyte being high would be a concern. But have no battery credentials.
Good luck!
Tom
Old 08-23-2004, 10:59 AM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
chuck
does your fridge switch automaticly between 120 and gas?
if yes, i imagine there is a control circuit running.
also, are your batteries clean? dirty batteries will discharge faster than clean ones due to current passing from one post to another through the crud.
john
you call them ferrets, i call them weasels.
Old 08-23-2004, 11:54 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by john hd
chuck
no. manual switch: "gas", "off", "elec". however, if left on "gas", and there's no flame (as if you ran out of gas, or are just starting it on gas), the ignitor runs on 12v, and the "no flame" indicator clicks and blinks.
john
they look clean to me. there's no crud trail leading from one post to the other. (battery is 1 year old).
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-23-2004, 12:26 PM   #5
Chuck,
I definitely boiled out my batteries with the Univolt plugged in full time.
So I bought a heavy duty timer and plugged the Univolt into it and the timer into the wall socket (just made two short heavy extension cords) and then set the timer under the arm rest on the curb side.
Then I set the timer to run 1 hour a day while plugged in. When taking it out, I just set it to 'on' continuously.
Sure cured the boiling problem!!
Steve in Sav'h
Sav'h Steve is offline   Reply With Quote
Old 08-23-2004, 01:06 PM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I use a blade switch on the battery post to disconnect it completely when sitting at home. I forgot last time to pull it and the digital clock drained the battery down over a few weeks. Also Optima batteries can take an almost complete discharge( down to 2volts or so) and be recharged with no loss of power or life expectancy. I put one in for my house battery.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-23-2004, 02:38 PM   #7
AirConditioner's Avatar
Is the Univolt really outputting 12.8 vdc?
How did you check the Univolt? Is it at least buzzing?
It's possible it's not putting out any 12vdc (reads 24vdc unloaded on a digital multimeter). I had a situation where the Univolt was buzzing and outputing, but the fuse to the battery was blown. With this fuse blown and shorepower on it appeared that all was fine. When I dropped the shorepower, no power because the battery fuse was blown! Since this also prevents the Univolt from charging the battery, I was not aware the battery was slowly discharging over a period of about 30 days,
I installed a timer as well to assure Univolt plays nice with the battery. I'm exploring building a small trickle circuit to taper down the available charge to the battery from the Univolt.
AirConditioner is offline   Reply With Quote
Old 08-23-2004, 02:55 PM   #8
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Chuck,
Check on the little lamps inside the storage compartments. They can get bumped on accidentally and if it is bright daylite, you may not notice. Good luck!
sander17 is offline   Reply With Quote
Old 08-23-2004, 03:56 PM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
the voltage at the battery goes up when plugged into shore power, so I'm pretty sure the univolt is charging the battery. as soon as its plugged in, the voltage slowly goes up...I didn't check to see where it tops out. what should it be? I seem to remember someone posting what it should be in the past, and thinking that it was about where it should be. but I'll double-check.
there are no little lamps in any storage compartments. its an oldy...
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-23-2004, 05:37 PM   #10
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
chuck
wouldn't that be a 12 volt load?
john
Old 08-24-2004, 07:36 AM   #11
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
chuck
john
well, yeah. but is it on all the time, or only when you're trying to start the fridge on gas? is there a little brain in there doing some sort of "thinking" at all times..like the thermostat?
btw, I checked the voltage thismorning at the battery (plugged in to shore power): 13.5. that sounds like a reasonable charging voltage, yes?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-24-2004, 08:02 AM   #12
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
We had a pretty good discussion about the draw down on my trailer as it sat in the storage lot. What's interesting is that with the master disconnect left on the sleeping electonics in the trailer and propane detector pretty much exhausted my battery within 45 days.
Here is the link to the thread with the details. I have yet to try this measurement on the Classic. http://www.airforums.com/forum...t=voltage+draw
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-25-2004, 12:13 AM   #13
spinolio's Avatar
Seconded, I have the same setup except I never got around to replacing the house batteries with Optima Blue tops, I do however have a Red Top starting battery.
(no longer)on the road...
www.curtandmandy.com
spinolio is offline   Reply With Quote
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Installing battery problem flyfisher Electrical - Systems, Generators, Batteries & Solar 2 04-01-2003 05:59 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
