Old 08-09-2010, 10:07 PM   #1
Long Beach , California
Battery overcharge?
Ok, so I have had my 08 sport plugged into the wall outlet for a couple months. I guess I forgot to turn my battery switch inside the trailer off. Is my battery ruined? Did it overcharge? Thanks! BC
bcripe is offline   Reply With Quote
Old 08-10-2010, 02:16 PM   #2
2005 19' Safari
GLENDALE , AZ
Check to see how much water is in it. If it didn't boil dry, it may still be OK. Also, disconnect the shore power plug and turn on all of the 12 volt stuff in the trailer. If everything works, you are probably fine.
Even if the water level is low, I'd try adding some water (do not add acid!) and charging it for a day or two. Then, try the quick test above.
Old 08-10-2010, 02:25 PM   #3
altnbndr's Avatar
1967 17' Caravel
1968 22' Safari
Sacramento , California
Images: 11
If you do need to add water make sure to get distilled water from the store to avoid adding minerals found in most tap water.
altnbndr is offline   Reply With Quote
Old 11-07-2010, 11:24 AM   #4
2005 19' Safari
GLENDALE , AZ
Just curious -- how did this turn out?
Battery in a '58 bevman Batteries, Univolts, Converters & Inverters 3 03-28-2007 09:31 PM
Which Battery ?? Pieter Electrical - Systems, Generators, Batteries & Solar 3 04-04-2006 02:27 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
Battery check--why don't I ever have to add battery water? Kistler Batteries, Univolts, Converters & Inverters 8 05-17-2004 09:03 PM
When A/S on AC, do you let the battery on ? brunoffrance Electrical - Systems, Generators, Batteries & Solar 8 11-02-2003 03:28 AM
