Old 11-02-2010, 01:30 PM   #1
1973 31' Sovereign
Fort Worth , Texas
Images: 27
Battery not charging
My battery does not appear to be charging.
It measures 12.8V when disconnected or connected to the trailer with TV connected and running or connected to 110.
All fuses on univolt appear to be good.
When I take off the cover over the 7-way the large blue cord in the middle measures 14v with TV connected and running.
Any suggestions on where to start?
Steve
We will soon begin traveling with our family of 5 (and a large dog) Looking forward to remodeling our Airstream, awesome adventures, and meeting new people.
www.steventothemax.com
steven2themax is offline   Reply With Quote
Old 11-02-2010, 01:36 PM   #2
1973 31' Sovereign
Fort Worth , Texas
Images: 27
I installed a battery kill switch so the battery stays disconnected except to raise and lower the jack, and I trickle charge it every time we get to a new place.
Old 11-02-2010, 02:16 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Measure both sides of the kill switch while the trailer is plugged into shore current and or the TV while running. If you see 13+ volts on one side and 12.8 on the other that switch is isolating the battery from the converter and the TV.
Not sure why you put that switch in. How does your freg work while on the road if you have the battery disconnected?
Depending on where you put that switch you may have disconnected your emergency brake system also.
Rethink that switch.
2004 Excursion 4x4
Old 11-02-2010, 05:04 PM   #4
1973 31' Sovereign
Fort Worth , Texas
Images: 27
Would love to rethink the switch. I put it in temporarily BC i thought something might be draining the battery, but i had more urgent things to fix.
I'll check on both sides of the switch. I did have to just replace this battery 9before the switch) even though it was new in July. No doubt bc it wasn't being charged.
Old 11-04-2010, 03:34 PM   #5
1973 31' Sovereign
Fort Worth , Texas
Images: 27
So I just remeasured and I got 12.46 at the battery not plugged into the shore and 12.89 when plugged in. Does this mean the 110 is charging the battery properly?
Old 11-04-2010, 03:54 PM   #6
HowieE's Avatar
Images: 12
Yes it is charging. That may be a maintenance charge rate because it is only slightly above the current battery voltage. Depending on the type of converter you have, some chargers have 3 different charging rates.
If you want to test it further disconnect from the shore and run the battery down with lights and or the jack retest the battery when it is lower and then plug into the shore and see if the charging voltage is above the 12.8.
2004 Excursion 4x4
Old 11-05-2010, 12:52 AM   #7
New Borockton , Alabama
Images: 21
Your Univolt is not charging your battery. If you saw 14 volts, that was bacause your TV engine was running and likely the only charge your battery has seen lately.
If you are reading 12.anything, you are not charging the battery from the univolt. It takes at least 13.5 to really do anything and that assumes a healthy battery.
Shut off switches (kill switch) is not the answer unless for some reason you don't want a parasitic load to drain your battery, ie CM detector, etc. Maybe during storage but even then a solar maintainer or modern multi stage converter/charger connected to shore power is the best.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Problem with battery charging Larry71 Batteries, Univolts, Converters & Inverters 9 12-14-2016 07:49 AM
Battery charging Jack46 Generators & Solar Power 6 01-31-2010 03:48 PM
MH/Battery Charging? 345bill Classic Motorhomes 4 11-06-2008 12:13 AM
Battery charging Dr Dan Electrical - Systems, Generators, Batteries & Solar 6 10-05-2008 06:04 PM
Battery Charging Hell guy99 Batteries, Univolts, Converters & Inverters 40 03-01-2008 10:56 PM
