Old 08-14-2015, 04:55 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Battery minder
I have two group 24s on 2015 FC28. What's the best Battery Minder to purchase?
DeltaRon is offline   Reply With Quote
Old 08-14-2015, 06:30 PM   #2
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
I am using the BatteryMinder Plus 1510 but after making sure batteries are charged.
TheCabin is offline   Reply With Quote
Old 08-14-2015, 06:36 PM   #3
65CV's Avatar
Western , Massachusetts
I like the Trimetric. The link will get you to bestconverters.com. Call Randy with questions -- he's a forum member here and is very helpful. (I'm just a happy customer).
65CV is offline   Reply With Quote
Old 08-14-2015, 07:11 PM   #4
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
After having my dad (mr electrical) provide me advice, I purchased a Promariner 6 for my two 24 batteries and used it until I moved into a storage with no electric. The 6 is enough to maintain and it takes something like 48 hours to charge them up if parallel setup is used. I purchased the single lead model and it shuts off and on and does just fine. They are also waterproof. The company he worked for used Battery Minder initially for their generator setups and had consistent failures. They went with these and have zero issues.
http://promariner.com/products/water...osport-series/
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 08-15-2015, 08:03 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Rod,
Thank's for that link....looks like a nice unit. Been looking for one for the boat.
Single batt...looks like this one will work fine
Old 08-15-2015, 08:18 AM   #6
lewster's Avatar
Naples, FL , Hood River, OR
Back to the OP's original question, the BatteryMinder 12248 is the most adjustable and has temperature compensation. It can be set for a 2,4 or 8 amp charge and liquid, gel or AGM type batteries.
I have several and they work perfectly!
Tire Minder or TST TPMS for 30' FC Beach Bum Tires 8 02-05-2015 12:25 AM
hook up tire minder transmitting booster roloha Electrical - Systems, Generators, Batteries & Solar 1 03-06-2014 08:43 PM
Air Filter Minder maxed out all the time Tony Lee Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 0 04-17-2013 08:51 PM
Battery Minder Question Jwestman Electrical - Systems, Generators, Batteries & Solar 3 11-18-2012 03:22 PM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
