Old 01-22-2015, 08:39 AM   #1
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Battery maintenance - solar tenders
Not sure if this should be here or in solar, but here goes:
Has anyone used a solar powered battery tender to keep their batteries topped up? I am seriously considering this to keep the batterie topped off:
Amazon.com: Battery Tender 021-1164 10W Solar Charger: Automotive
at the moment I am leaving my AS connected to shore power when at home...
Thanks in advance for the feedback.
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 01-22-2015, 09:46 AM   #2
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I do this on several vehicles,
There's a solar maintainer in my Airstream and Tundra, I've managed to keep the truck's factory 2005 battery alive - 10 years and counting. I use the 12v lighter adapter in the trailer and truck (make sure your lighter outlet has power when key off) and we're always charged up and ready to go. Just leave the solar panel in the window.
I mounted a solar charger on the roof of my enclosed car trailer with an outlet inside to connect to the battery of any car I have parked in the trailer for the winter.
I use plug in battery tenders on my collector cars in the garage since they're in the dark but the solar charger works great for anything outside since I don't have to run power outside and it's free to operate!
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 01-22-2015, 10:41 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I use one for my truck in the driveway since I only drive it every few weeks. I also used to use one on a boat for the outboard starting battery. Worked like a charm.
Larry
lsbrodsky is offline   Reply With Quote
Old 01-22-2015, 11:46 AM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question Does Oregon.....
......have more Sun in Winter than Buffalo?
I had 30w of portable solar, was fairly dependable in Summer, not so much in Winter. 10w would be very marginal in cloudy conditions.
FWIW... I would not leave on shore power 24/7, you risk overcharging.
Couple hours when batt's are at 12.5v.....or use a Battery Tender....or upgrade to a 3 or 4 stage converter and leave plugged in.
Old 01-22-2015, 12:39 PM   #5
Gsmblue's Avatar
Bend , Oregon
Thanks for all the feedback. I understand the risks of being on shore power all the time, hence I am looking at changing through other means.
How are people connecting the tenders to their batteries? Are you direct connecting to the battery, through the a 12v automotive outlet that is connected to the converter or is there another input on the converter that can be used?
Old 01-22-2015, 01:53 PM   #6
Thumbs up
Our TV doesn't get used a lot over the Winter, to overcome the parasitic drain...I plug the BT into a 12v power port, maintains @ 13.0v.
If your power port is live it should charge fine.
Old 01-22-2015, 02:01 PM   #7
Gsmblue's Avatar
Bend , Oregon
Thanks Bob!
Old 01-22-2015, 04:50 PM   #8
2013 30' Flying Cloud
Livermore , California
I use this kit from Renolgy on my Flying Cloud while its in storage; I purchased some extra solar cable so I can put the panel at the end of our storage space on a home-made PVC rack. I has worked well and Renolgy support replaced the controller at no charge when it failed. I created a permanent pig tail to connect the solar to the battery bank and mounted the controller under the propane tanks with velcro to keep it out of the weather (the controller is not water-proof).
50W Mono Bundle | Renogy Store
bird_dg is offline   Reply With Quote
Old 01-22-2015, 04:56 PM   #9
Gsmblue's Avatar
Bend , Oregon
Bird_dg
That is EXACTLY what I am looking for! The installation is also what I was thinking of! Thank you!
I am going to order that up without even discussing with the wife!
Old 01-22-2015, 05:10 PM   #10
If she asks, just tell her that the cost of the solar panel is cheaper than replacing both the batteries; that worked for me!
Old 01-22-2015, 06:29 PM   #11
dznf0g's Avatar
Oswego , Illinois
Taking into account cloud cover, night, and parasitic drains with master switch off, 15 watts works for me.....10 wouldn't.
-Rich-
Old 01-22-2015, 08:22 PM   #12
Gsmblue's Avatar
Bend , Oregon
Bird_dg do you have any pics of your install? I would really appreciate it if you could share
Old 01-22-2015, 09:20 PM   #13
Gsmblue's Avatar
Bend , Oregon
Ended up getting a Renogy 100W mono panel with their MPPT charger.. a bit more then I planned to pay but hopefully this will be a more capable system we can use all year round...
Old 01-23-2015, 07:48 PM   #14
1966 20' Globetrotter
2008 23' International
Cedar Falls , Iowa
Send a message via AIM to hahnstead
I use a portable 10w solar charger to keep several batteries charged over the winter. The batteries from my two Airstreams, my golf cart, and my mower are kept in a room in my house with a southern window. The charger is placed in the window, and I keep each battery connected to the charger approximately one week per month. Has worked well for me.
Hahnstead Airstream Park
hahnstead is offline   Reply With Quote
How to Climb onto the Roof of an Airstream Travel Trailer Solar Maintenance Seal Leak Doc Foster Roof 2 12-12-2014 02:48 PM
battery tenders over winter time jim1949 Batteries, Univolts, Converters & Inverters 15 09-12-2013 09:44 PM
Solar Power for Battery Maintenance Tumajin Generators & Solar Power 10 08-12-2011 06:10 AM
Battery Maintenance, replacement or bad charger? jacarape Batteries, Univolts, Converters & Inverters 20 06-09-2008 08:11 AM
Cold weather battery bank maintenance Boondocker Generators & Solar Power 16 12-22-2007 10:23 PM
