Old 03-31-2011, 07:24 AM   #1
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Battery Maintenance Question
Not sure where to post this. I have a solar panel for my batteries and the service battery light is blinking to add water to the batteries. I have checked the manual and can not find out how to slide the batteries out to service them. After you unlock the battery door, what do you have to do next to get the batteries out? I can't imagine that a diagram wasn't included in the manual. As a relative nubie, it is frustrating but I don't want to mess up anything. Thanks in advance-
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 03-31-2011, 08:25 AM   #2
1971 29' Ambassador
Leonardtown , Maryland
It is a brute force thing, grab the cable closest to you raise up the end of the battery and pull it to you enough to loosen and remove the cable. Slide the battery out enough that it stays balanced and remove the other cable. When you remove the first cable put a plastic bag over it and tape it on the cable so it does not short out, do the same with the second cable. Your other battery is still connected and the wires are hot.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 03-31-2011, 08:32 AM   #3
dznf0g's Avatar
Oswego , Illinois
I unstalled a nylon strap with a cinch buckle around my batts. I also tied a knot to form a loop so I can grab and pull. I wouldn't pull on the cables. 1) you can damage the cable to terminal connection and 2) you can damage the post on the battery causing an acid leak.
Old 03-31-2011, 09:19 AM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I have had to do what Rebee suggested - just be careful and gentle. And before you push them back in, do what dznf0g did - but not a cotton one, as it will rot pretty quickly. Leave it a little loose so you can twist a stick and use it for a handle.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 03-31-2011, 09:25 AM   #5
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
I leave the carrying strap on my batteries when I put them in the compartment. When removing, I grab the end of the strap, lift the battery over the lip and slide out on top of the door. If you don't have a strap on the battery, gently grab the cable, lift and slide.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
au_ee is offline   Reply With Quote
Old 03-31-2011, 09:14 PM   #6
pappy19's Avatar
I wondered about that, lifting the edge of the battery but was afraid I would break something. As it turns out, I called my tech that installed my solar panel and he said to check the solar fuse in the fridge compartment. I opened it up and the fuse was in a small pool of water and blown. I installed a new fuse and taped the fuse/wire so it would not touch the floor. No more worries. Thanks for the suggestions on servicing the batteries; I will need to do that anyway in the near future.
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
Battery Bank Upgrade Gwuk Batteries, Univolts, Converters & Inverters 5 03-24-2011 08:18 AM
Original AS Converter Question Hummer Batteries, Univolts, Converters & Inverters 4 02-25-2011 04:22 AM
Only one battery charging heslinhotel Batteries, Univolts, Converters & Inverters 11 02-21-2011 08:49 PM
'67 Caravel Restoration Electrical question vonzellen 1966-68 Caravel 1 01-15-2011 07:25 AM
