Old 08-20-2011, 06:25 PM   #15
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
"a defensive posture indicates some issues that need to be resolved?"
Nothing is more discouraging than unappreciated sarcasm.
PFC
but Im the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-20-2011, 06:30 PM   #16
A girl and an Airstream
missysanford's Avatar
1993 29' Excella
dunnegan , Missouri
We had the converter checked about 4 years ago and it was fine. We put new batteries in at that time. Ours is a 1994 and we needed new batteries then because they were old so we just did it to get up and running. I would say 99% of our camping is in farm fields in the fall, winter and early spring. We are hard on our batteries so we weren't concerned when they said 2 years on our marine batteries were about all we would get. I'm still not going to run out and get the converter checked unless we are in for another reason. We just don't have time.
The fact that the 2005 Airstream is not holding a charge is not unusual. We don't know how old his batteries are but assuming they are original, 6 years is pretty good. We would need more information to make any kind of educated guess.
I feel these forums are good, both experienced answers, a little bs, and some just funny. When I ask a question, I expect a bit of all three. Airstream owners are some of the most diverse and interesting people on the planet and they all make me think outside the box.
Oh and sometimes, those that ask questions are looking for an entirely different answer than they know. How about this: If you have time to test your batteries all the time, you need to get out and use your Airstream more! Enjoy the travels...
missysanford is offline   Reply With Quote
Old 08-20-2011, 07:06 PM   #17
Southwestern , Ohio
LEDs help a lot
If you are going to boondock, the most important single thing you can do is replace your 12 V incandescent bulbs with LEDs. 'Tain't cheap, but they cut your lighting power consumption by about 90% without decreasing the amount of light.
Nuvite-F is offline   Reply With Quote
Old 08-20-2011, 08:08 PM   #18
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
You say the LED replacement isn't cheap, but I'd point out that with a reasonable amount of bargain hunting you can probably upgrade every light in the trailer for no more than the cost of a couple of decent deep-cycle batteries. It seems like a pretty good trade-off, since the LEDs will likely last many times as long as the batteries AND extend the life of the batteries you already have.
David
Old 08-20-2011, 08:21 PM   #19
Just ordered three 1156 led's for the outside storage compartments, (there the ones that stay on at random if anything moves around in there)... 11 bucks ea. on sale
PFC
RLC
Old 08-20-2011, 08:41 PM   #20
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
I have fitted all lights in our 65 Safari with LED's and even installed 8 under cabinet LEDs. Also up graded the converter to a good 3 stage model. We have installed 3 Lifeline AGM's and can boondock 4.5 days during the summer before a charge. Our biggest draw is the Sat. & TV.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 08-20-2011, 09:00 PM   #21
2009 25' FB Flying Cloud
North Bend , Washington
I vote for the AGMs. I neglected mine over the winter and returned them and was talked into the standard deep cycle marine batteries. These last barely through the night and don't hold a charge near as well as the AGMs. Spend the extra money.
Lahontancut is offline   Reply With Quote
Old 08-20-2011, 10:14 PM   #22
Mexray's Avatar
1978 28' Ambassador
Morada , California
Lots of discussion about Amp Hours, system loads, etc...
The fact remains that Optima Blue Top Deep Cycle batteries DO NOT have the capacity of rectangular, 'flat plate' batteries!
The 10 inch Optima's are rated at only 55 Amp Hrs - a Group 24 flooded cell battery of the same size can be rated up to 80 Amp Hrs - that 45% MORE capacity...!
If you can fit the 12 inch Group 27's into your battery box, you can get up to 105 Amp Hours per battery...
The additional Amp Hour rating can be a big deal when boon-docking! Also, charging each day with your generator goes a long way to avoid an undercharged condition...
Ray & Pat; Morada, CA
Old 08-21-2011, 07:45 AM   #23
1993 29' Excella
dunnegan , Missouri
Nobody has mentioned that keeping them charged without discharge can affect performance too. What about that? I'm just saying'....
Old 08-21-2011, 08:26 AM   #24
timmaah's Avatar
1999 25' Safari
On , the road
Simple DIY and you can get the cost down to under $3.50
1.2w 12V Warm Led for $2.87
G4 1.2W 108-Lumen 3500K 24-SMD LED Car Warm White Light Bulb (DC 12V) - Free Shipping - DealExtreme
1156 Base - $.50 (Search for BA15S-EB: BA15S Empty BA15 base)
LED Accessories & Motion Sensor Lights - Super Bright LEDs
Solder 2 small pieces of wire to connect..
timmaah is offline   Reply With Quote
Old 08-21-2011, 08:32 AM   #25
1993 29' Excella
dunnegan , Missouri
How did you know which ones to buy?
Old 08-21-2011, 09:10 AM   #26
Tried a warm white square cluster for the stove light, not bright enough,
changed it out for the bright white.
Used the "puck" style warm white for the for all the interior overheads.... don't think the round cluster would fit the fixture for the outside compartments.
The bright white 20 cluster tower seemed like a better fit for them.
Past lesson learned...if your changing your outside bulbs, they will be much brighter and look better if you match bulb color to lens color.
PFC
RLC
Old 08-21-2011, 09:17 AM   #27
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Thank you Mexray, I was wondering when someone was going to point that out.
Ahab is offline   Reply With Quote
Old 08-21-2011, 09:22 AM   #28
That is all true.
Assuming perfect maintenance, agms and flooded cells last about the same time but I always forget to add water, or use tap water instead of distilled and shorten the life of my flooded cells. However, they are about half the cost of agm's
I am going to upgrade my stock converter to a phased converter charger. The stock converter always dumps a full charge into the batteries and will kill them in a hurry if your trailer is always plugged in. In the meantime, the only time my trailer is plugged into shore power is when I am recharging the batteries or the few times I am in a campground hooked up to shore power.
Two 6 volt golf cart batteries will supply more amp hours than two twelve volts of the same dimensions.
If you rebuild the battery box, there is space for even bigger batteries--a thought if you are going to boondock long term.
I am going to experiment with a wind charger. I believe it will plug in to the 12 volt power recepticle. Between it and my solar panel, I should have enough juice to eliminate or greatly reduce my generator run time.
handn is offline   Reply With Quote
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 03:33 PM
Battery Issues aswbe Batteries, Univolts, Converters & Inverters 29 08-08-2011 08:27 PM
Only one battery charging heslinhotel Batteries, Univolts, Converters & Inverters 11 02-21-2011 09:49 PM
