Old 12-09-2008, 10:05 AM   #1
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
birmingham , Alabama
Images: 26
battery life/length of stay
I currently don't have my 64 overlander wired to use a battery. so far we've only used it at sites with electric/water hookups but am prepping it now to visit a national park which boasts no water or electric....
just curious as to what kind of duration I could expect from a fully charged battery and average use of lights, heater blower, water pump, etc.
I know the short answer is 'it depends' but I have really nothing to gage this on since I have yet to use the batt.
Doug
59er is offline   Reply With Quote
Old 12-09-2008, 10:28 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Our first A/S, 63 Safari, air compressor h2o pump, w/single 27series r/v battery, about 3 days boon-dock'n with VERY limited use.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-09-2008, 10:35 AM   #3
SteveH's Avatar
Common Sense , Texas
Doug,
The heater fan uses lots of power, and so if you use furnace at all, it will really cut your battery's charge....probably discharge it in one night. The water pump also uses a lot, but it normally does not run as long as the heater blower. Next are the incandesent lights. Use them sparingly, or use florescents, or the ones that take the least amount of current are the LED lights. But, the LED replacements are expensive.
Regards,
Steve
Old 12-09-2008, 10:46 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
A definite case of your mileage may vary. Only one battery? You may be limited to one night at a time with minimal furnace use. I bring warm bedding and set the thermostat in the upper 50s to keep it from running constantly if it's real cold out.
You'll last longer if you don't use lights. We use a couple small LED lanterns when we boondock. I principally want to keep the fridge, water heater & water pump running. Your endurance would be in multiple days running just those.
You want to avoid drawing your battery below 50%. Drawing down completely wil shorten its lifetime significantly and impact capacity immediately if you discharge it completely. The easiest way to monitor is to get a compact volt-ohm meter (VOM). I got mine at Home Depot but there are many possible sources. Then use the chart Nick Crowhurst put up here in the last week - http://www.airforums.com/forums/f449...tml#post643843.
Hooking up to your running tow vehicle daily for 15-30 minutes will accomplish almost nothing for a number of reasons. We use a Honda eu2000i for dinner hour if we want more lights or use the microwave when boondocking.
5 meter Langford Nahanni
Old 12-09-2008, 11:30 AM   #5
Central , Mississippi
Originally Posted by 59er View Post
... to visit a national park which boasts no water or electric....
just curious as to what kind of duration I could expect from a fully charged battery and average use of lights, heater blower, water pump, etc...
This past May/June we spent a few day in the Tetons and Yellowstone with no hookups (there's a thread here somewhere...). We added a second battery to the trailer harness (again, there's a thread here somewhere of how I did it...) and used a Honda 2000 genset. We didn't skimp on usage, the heater ran a bunch and we watched Sat TV for an hour or two after quiet time. The Honda didn't charge very good using the old univolt and by the end of the week it had toasted one of the batteries. We pretty much had to recharge every day. Based on all of my calculations, I believe with my new 3 stage charger we have enough capacity to do the same thing, but recharge every other day.
The heater is my big pull...but momma had to be warm and happy
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-09-2008, 11:36 AM   #6
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by SteveH View Post
... Next are the incandesent lights. Use them sparingly, or use florescents, or the ones that take the least amount of current are the LED lights. But, the LED replacements are expensive.
Surprisingly, most LED's DO NOT live up to the hype - as per tests and Dept. of Energy articles - reference here:
LEDs are efficient for some applications and here:
Don's Lighting Info Center!
have determined that in MOST INSTANCES Fluorescents still produce more lumens per watt.
I purchased several (relatively) high dollar LED arrays when I redid the '78 Sovereign's lighting system, and am sorely disappointed with the outcome.
Many LED's are burned out on one array, and two others do not put out nearly the lumens I had hoped for.
Best to see an actual demonstration of a light fixture before putting your money out.
They're getting better, but quality is still not consistent.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 12-09-2008, 11:37 AM   #7
SteveH's Avatar
Just my opinion, but I think if I wanted to do much boondocking in cold weather, I would get one of the propane catalitic (sp?) heaters.
If it was much below freezing, I wouldn't be there, boondocking or otherwise.
Regards,
Steve
Old 12-09-2008, 12:15 PM   #8
Over59's Avatar
Putnam , Connecticut
Images: 37
There is also the issue of how long your water last. It's all in the end users expectations of comfort.
Over59 is offline   Reply With Quote
Old 12-09-2008, 01:56 PM   #9
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
all good points.
would it do any good to use a small generator if for no other reason than to recharge the battery during the day (since there are usually quiet times at night...)?
like a small 900 to 1000 watt, 8 or 9 amp type?
Doug
Old 12-09-2008, 02:16 PM   #10
Thumbs up Using a generator?
We used a Yamaha 1000 with our "63", a very good "small" unit.
A two hour run usually got us through another day. When we got the Classic it was replaced with a Honda 2000 that now has a Lpg/gasoline conversion.
Name:	Safari sale complete with generator.jpg
ID:	72423   Click image for larger version
Name:	PROPANE CONVERSION, HONDA 2000 001.jpg
PFC
"Tahawus"
RLC
Old 12-09-2008, 02:23 PM   #11
59er's Avatar
1959 18' "Footer"
1964 26' Overlander
Images: 26
wouldn't still have the 1000 for sale by any chance?
Doug
Old 12-09-2008, 02:25 PM   #12
Thumbs down
Sorry.. we sold it with the trailer.
PFC
"Tahawus"
RLC
Old 12-09-2008, 04:03 PM   #13
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
The heater is the BIG draw. One fairly cold night will kill two good batteries. We find the other loads are manageable for 2 to 4 days of careful use. Lights on only when you need them, careful water use, etc. doesn't use a lot of power. I have made it 5 days, in mild weather (no heat).
One big trick an old timer showed me was to turn off the "moisture" control on the refer. This is a heater that is intended to function something like a defrost unit in a home refer. It is very power hungry too.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-17-2010, 03:47 PM   #14
This is a really old thread but I'm going to post this info here.
I measured the amp draw of various items on my '91 trailer-
Here's what we have;
.9 amps for the fridge
.5 amps for the water heater
6.5A Heater fan, 7.8A heater running
1.82A for the fantastic fan running on low, 2.5 med 3.4 high
2.4A kitchen sink fluorescent
1.9A stove fan, 1A for the hood light
1.1A bath lamp on low, 7A on high
11A living area lights on high
2A outside step lights
1.5A for the small square over head reading lights (each)
Direct TV receiver 18 watts, 61watts with 13"tube type tv (6.5A on the inverter)
I'm using these values in a spreadsheet to model my usage on a simulated hourly basis and see how solar/gen/bigger batteries work before I spend the bucks.
Battery life moosetags Batteries, Univolts, Converters & Inverters 28 10-20-2016 07:56 AM
Short Battery Life 1Bombshell Batteries, Univolts, Converters & Inverters 32 09-16-2008 10:06 PM
overall length and campgrounds tetstream On The Road... 7 07-30-2008 12:58 PM
battery life w9det Batteries, Univolts, Converters & Inverters 23 06-02-2004 03:08 PM
Actual Length Stormy Weather 1997 - 2004 Bambi 4 08-21-2003 05:09 AM
