Old 01-17-2010, 04:34 PM   #15
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Originally Posted by 87MH View Post
Surprisingly, most LED's DO NOT live up to the hype - as per tests and Dept. of Energy articles - reference here:
LEDs are efficient for some applications and here:
Don's Lighting Info Center!
We replaced 6 of our incadescent lights with LED's this spring. Bought arrays with adapters to replace the old 1157 (or is that 1156) bulbs that are normally used.
1 Bulb draws about 1.5 amps or 18 watts.
All six of the LED lights together draw under an amp. The light is a bit whiter than I would like but the brightness is ok for reading or anything else.
Out flourescent light draw about 2 amps,
We are quite happy with everything about the LED lights except cost.
It ran about $ 30. per light.
We have found these reduce our daily useage by about 10 amp hours.
I bought mine at a hamfest but the same product is available from Visit Our QuickShop Store To Buy LED Lighting for RVs and Boats
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-17-2010, 08:18 PM   #16
tallytwo1994's Avatar
tallahassee , Florida
Originally Posted by HiHoAgRV View Post
.9 amps for the fridge
I'm using these values in a spreadsheet to model my usage on a simulated hourly basis and see how solar/gen/bigger batteries work before I spend the bucks.
Does this mean the fridge draws .9 amps per hour?
Carol
tallytwo1994 is offline   Reply With Quote
Old 01-17-2010, 09:09 PM   #17
Central , Mississippi
Carol
Yup. Mine does. 24 hours a day, 7 days a week, as long as it's on....
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-18-2010, 04:43 AM   #18
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Since I have never had a modern fridge, Have you actually measured the current? I had assumed it was smaller than that except when igniting the burner??
.9 amps continuous equals 21 amp hours per day which is a serious draw.
We typically use 30 to 40 amp hours a day without refrigerator electric load
It's the small constant load that get you.
If the actual current draw is always this high a battery would be dead in 3-4 days if you left the fridge on while parked.
13 Ram 2500 TD
Old 01-18-2010, 06:03 AM   #19
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
POI...there is a hi-humidity condensation switch(?) that if on, will keep the interior light illuminated 24-7. , never picked up on when reading the manuals, my bad.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-18-2010, 08:48 AM   #20
Yes that was a measured reading. I had a digital ampmeter in the power feed line. By turning on one system at a time i could record the draw.
I'll remeasure this afternoon, the moisture switch was ON but the interior light wasn't on. The Door switch sticks and I seem to recall the light was off when I opened it.
Old 01-18-2010, 09:16 AM   #21
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Save yourself all that troublesome measuring and thinking
Get the two largest batteries deep cell batteries that will fit, think conservation (i.e. nix the furnace) and have a great time. Also be aware that you wont be allowed to use generators in all National Park campgrounds. My two battery bank with conservation procedures gives me at least a week between charges. When I don't pay attention to energy use, I only get half that.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 01-18-2010, 09:17 AM   #22
2008 16' Safari
Destrehan , Louisiana
We are able to make one night on the battery. This is with the DC running the lights, TV and heater. We recharge the battery from the tow vehicle and can make an other night. After two nights, the water is getting short and the grey water tank in getting full.
We also have an 1800 watt generator that will give full power to the trailer. The only limit is how long you can go without dumping or running out of water.
Your results will vary!
If you live like a hermit, burn candles, don't run the TV or radio, use a little Coleman heater and don't shower; you could probably go a week or so.
If you run everything, keep the lighs on and don't conserve; you will not even make the first night!
The best thing I can tell you is to just do it. Make a test camp at home or near by and see how it goes.
dlb435 is offline   Reply With Quote
Old 01-18-2010, 02:02 PM   #23
Ok,
.9 amps drops to .4 when the climate control switch is turned OFF on my RM2820
With the switch ON and the door open (light on) it jumps to 1.8 amps
Apparently the interior lamp and the climate control are different current draws.
Old 01-18-2010, 02:13 PM   #24
Originally Posted by Gen Disarray View Post
... think conservation (i.e. nix the furnace) ...
Me thinks the missus would nix the trip...
The main reason for my figgerin' is to see what time of the day I have an issue. We typically use the most energy in the evening, then run the furnace at night.
Right now the numbers tell me 180 watts of solar, 3 grp27 batts and 1 hour of the Honda 2000 in the evening should be enough.
The disco ball with LED's and 80" big screen really don't pull that much compared to the popcorn machine and beer dispenser/cooler...
Making a math model is a diversion during the cool, wet weekends when I can't camp...
Old 01-18-2010, 02:17 PM   #25
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Ok,
Thanks for checking it. I have been trying to get a "real" number on this for quite a while and the Dometic salesman I talked to were no help.
One of these days I will probably be forced to get a new fridge and since we use solar all these things count.
13 Ram 2500 TD
Old 01-18-2010, 05:36 PM   #26
That may very well be for the 2820. All it says for the RM3662 is that will draw 12v DC when turned on and to make sure it's off when a charging source is not available.
PFC
"Tahawus"
RLC
Old 01-18-2010, 05:58 PM   #27
64GlobeTrotter68Overlande
man7sell's Avatar
1964 19' Globetrotter
1969 27' Overlander
Snohomish , Washington
I agree with the 2 battery bank with deep cycles, mine total 200 amphours. I have also installed a marine type smart battery charger for when it is on shore pwer to ensure a proper recharge and conditioning when needed. Also in circuit is a marine battery switch that can use one battery at a time, so when the voltage starts to get low on the first then I'm half way through my bank.
Next I want to install solar cells to extend the boondoggle time.
The Toyota TV also has an AC output when the vehicle is running so if it's a shorter trip to the next site I can get a better charge (Last resort).
Of course having a wholsale account at my local marine distributors helps
Anyone ever installed a RAT (Ram air turbine) for charging on the go? Airplanes use them for emergency hydraulics or and AC power. Having a turbine on tow while towing could give an extra charge.........
man7sell is offline   Reply With Quote
Old 01-18-2010, 06:09 PM   #28
man7sell's Avatar
1969 27' Overlander
Battery install photos
Here's my marine install system
ID:	94300   Click image for larger version
Name:	Battery switch.JPG
Battery life moosetags Batteries, Univolts, Converters & Inverters 28 10-20-2016 07:56 AM
Short Battery Life 1Bombshell Batteries, Univolts, Converters & Inverters 32 09-16-2008 10:06 PM
overall length and campgrounds tetstream On The Road... 7 07-30-2008 12:58 PM
battery life w9det Batteries, Univolts, Converters & Inverters 23 06-02-2004 03:08 PM
Actual Length Stormy Weather 1997 - 2004 Bambi 4 08-21-2003 05:09 AM
