Old 11-04-2014, 06:35 PM   #1
Johnsito's Avatar
1997 31' Land Yacht
Battery issue or something else?
I have a 1997 Land Yacht on a GM chassis. A few weeks ago, while I was out of town, my wife met some acquaintances of ours at the RV to let them take a look as they indicated they might be interested in buying.
The husband evidently is a tinkerer, so proceeds to tinker and check things out. They let my wife know they felt the RV too big, so were not interested.
A week later, I get home and go to the RV to give it a short ride just to keep the engine used. I do this periodically. To my surprise, the engine would not turn over. It would not even respond. In checking, the tinkerer had left the interior dash light on, as well both roof a/c's. All 3 batteries were completely drained.
I took the batteries home and trickle charged them all to full. I reconnected them to the RV and turned the key. The dash electronics responded, but when I crank, I get a clicking noise and the engine still won't turn over. I did some initial research, but before I do a ton of trial and error or expense, I would appreciate if any of you have any ideas of what the issue could be.
Bad battery connection? Solenoid? Alternator? I'm just not sure.
Thanks in advance for any input and advise.
Johnsito is offline   Reply With Quote
Old 11-05-2014, 07:44 AM   #2
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Your batteries are toasted.
Ahab is offline   Reply With Quote
Old 11-05-2014, 07:56 AM   #3
1974 Argosy 20
Kooskia , Idaho
Be absolutely sure that the battery connections are all clean and tight, every one of them. If in doubt about cleaning them, go to an auto parts store and get a terminal cleaner and use it on each connection, battery and terminal.
If that does not bring it back to life, you may have a battery replacement in order, but it is hard to tell from a distance.
Another test: Have someone with you to help, turn on the headlights to see if they light. Have someone try to crank the engine while you watch the headlights. If they go out immediately upon attempted cranking, you have a terminal issue. If they go dim with this test, you have a battery issue.
Old 11-16-2014, 07:32 PM   #4
Johnsito's Avatar
1997 31' Land Yacht
It was the batteries. Two of the three were completely dead and not recoverable. They were also out of warranty. Got the new batteries and it started right up. Thanks to everyone for your sound advice.
Old 11-16-2014, 08:03 PM   #5
Zil
egg harbor city , South Jersey
Hope you replaced all three. At least they were old.
Zil is offline   Reply With Quote
Old 11-18-2014, 07:19 PM   #6
Johnsito's Avatar
1997 31' Land Yacht
Replaced two. The third was only a year old.
Old 11-18-2014, 08:17 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
You should also send the battery bill to the 'tinkerer' with a little post script instructing to keep his hands in his pockets next time around!
Old 11-18-2014, 09:54 PM   #8
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Amen to that!
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 11-19-2014, 04:36 PM   #9
Johnsito's Avatar
1997 31' Land Yacht
True.....true.
Is this filiform corrosion (photo attached)? Or something else? Direwolf Buyer Guidelines 7 12-23-2010 03:32 PM
Air nibbler, hand nibbler or something else? SilverHoot Ribs, Skins & Rivets 9 08-17-2010 09:56 AM
Argosy Dump Valves or something else?? Denise M. All Argosy Trailers 6 05-21-2007 04:36 PM
Why Does My A/S say one thing on one side and something else on the other Angel73 Title, VIN & Registration 3 05-12-2006 09:46 AM
Walbernize - Or Something Else montanaandy Cleaning, Stripping & Polishing 15 04-09-2006 10:43 AM
