Old 09-09-2012, 06:02 PM   #1
1987 32' Excella
Middlesex , North Carolina
Battery Issue
Would like to know if anyone has had a problem with a new battery overcharging and emitting a bad smell? Two new batteries installed about a month ago, only one has a problem.
Thank you,
Fatboy99 is offline   Reply With Quote
Old 09-09-2012, 07:01 PM   #2
SteveH's Avatar
Common Sense , Texas
I had one battery explode because the other had a shorted cell and the charger, a three stage, kept pumping the juice to them.
I would recommend you shut down the system, isolate the batteries (disconnect one of them), give them a few hours to stabilize, and then check them thoroughly.
Old 09-09-2012, 07:27 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If there is a bad smell the battery is likely being overcharged most likely due to a problem within the battery. I would take it back where you bought it.
Old 09-09-2012, 08:54 PM   #4
mefly2's Avatar
2015 25' FB Eddie Bauer
Also check that the converter / charger is not overcharging ... hydrogen sulfide gas is given off during charging (rotten egg smell) and is also flammable ... even explosive in confined spaces. It might just be coincidental that the converter has gone bad rather than the old batts being bad ...
Old 09-10-2012, 07:31 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Also make sure the converter/charger is the right type for the batteries in question. Using a charger optimized for wet cells is not good for AGM batteries, and vice versa.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-11-2012, 06:32 AM   #6
1987 32' Excella
Thanks for all the advice and info shared. It was a bad battery and it has been replaced. That was a close one! Will never forget that smell!
