Originally Posted by 60's Iron
Going thought my new to me 58 Traveler. Battery looks like a po install. Not to clean..... Did it come stock with one? Also has a 12 volt water pump. I do believe orginal was air presure I'm I correct ?
My '57 FC had no onboard
12V system. I rewired it with an Intellipower and battery with fuse panel under the curbside dinette. The orig. wiring had you thethered to the tow vehicle with minimal lighting or 110V shore power.
The p.o. had added a battery box to the hitch area mostly to run a water pump.
