Old 12-28-2011, 02:13 PM   #1
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Battery Extraction Tool?
Having a knuckle-busting time slipping those two huge, heavy LIFETIMES out of their little doghouses to put them on the charger. SURE, they have a nice handle on the **top** where it is more or less useless behind the end-mounted aluminum doors. Who has an ingenious device for gripping-and-pulling those sweethearts out? 1999 30' Excella 1000.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 12-28-2011, 03:02 PM   #2
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
nylon strap
when replacing the batts, put a nylon strap (think old motorcycle tie-down) around the battery(ies) to make sliding them out the next time easier. if you can work a plumber's snake or electricians snake or some other thing around your batt while in the hole, then you can run something around the back side and pull them out. One caution: do your best to completely disconnect the battery before trying to snake something around them-use a plastic snake device if possible.
wmarsha is offline   Reply With Quote
Old 12-28-2011, 03:39 PM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Greg, a flat sheet of metal with a lip at one end that's narrower than the battery could be slid underneath—lever one side of the battery up to force the lip under. You only need a sheet a few inches wide that fits under the side that has been raised. I think some cookie sheets may be like that. If you can get it all the way to the back, the lip will help you pull it out. The other one should be easier since you will have more space.
There are other pans that have a lip all the way around and if the battery fits between the sides, that also could work.
Or charge them in place, but you probably can't do that or you would have by now.
Other less helpful suggestions: 1. Tilt front of Airstream up about 45˚ and they'll slide out; 2. Attach Airstream to high powered dragster and let 'er rip while the batteries are tied to a rope tied to a tree.
Gene
Old 12-28-2011, 04:51 PM   #4
1994 30' Excella
Mississauga , Ontario
I have the same problem. Just removed them two days ago. I always take a 6 inch putty knife with me. I lift the end of the battery just enough to slip the blade under about half an inch and then they come out quite easily. For the next time I think I will put a strap around the battery as well to make the removal even easier.
Al
Al and Jean
TAC ON-3
Old 12-28-2011, 05:06 PM   #5
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
A Variation on the Theme...
I had a sheet of clear plastic that I used to make a version of the cookie sheet idea.
The plastic was from a product package. The package had a clear plastic front to display the product. It's about .020 thick (think heavy card stock). You can buy something similar at the hardware store.
I cut the plastic about 3 to 4 inches wide and made it about twice as long as the depth of the battery compartment. I folded it 90 degrees on one end so it extended about 4 inches up the back end (far end) of the battery. Once I had the batteries out I slipped the plastic under the battery and I used heavy duty aluminum clad duct tape (the tape withstands extreme hot and cold temperature) to affix the 90 degree plastic flange to the battery. The other end of the plastic is a tab so you can grab it with your fingers. You could even make a hole/slot in this free end to make a handle.
Now the battery slips in and out of the compartment easily. All I do to remove it is grab the lip of plastic, lift slightly to get it over the lip of the compartment, then a gentle tug.
I also use a thin piece of this same plastic to prevent "shorting" the battery terminal as it slides through the opening.
Clear as mud right?
nvestysly is offline   Reply With Quote
Old 12-28-2011, 05:13 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
One of these stays right in the compartment next to the battery.
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
Old 12-28-2011, 05:16 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
Depending on which Lifeline model you have, they should have either a rope handle on either end or a 'trestle handle' at the top that has a space to insert your fingers to allow for battery handling.
If you have neither, perhaps a PO removed them. If YOU are the PO and these handles are not present, perhaps your battery source removed them.
Can you shed additional light on this mystery ?
Old 12-28-2011, 05:28 PM   #8
krlajwvater's Avatar
2003 30' Classic
mount joy , Pennsylvania
I have had 4 Lifetime batteries since 2006 and have never taken them out of the trailer for the winter. I just disconnect them at the converter, so there will be no draw on the batteries, the trailer is in storage for 4 months in the winter, and the batteries stay fully charged. After taking the trailer out of storage, I reconnect the batteries and they are good to go.
krlajwvater is offline   Reply With Quote
Old 12-29-2011, 06:26 AM   #9
2011 31' Classic
Images: 8
Wow, thanks for all the good ideas, folks! We'll look into adopting the "under plate" concept or the putty knife stored in the compartment, possibly along with some sort of pull strap. @lewster: Thanks for asking. The batts both have the black top handle. I can, and do, use the small black tab under the handle bracket to get some "purchase" to start moving them. Also most interesting to hear that one can actually leave them alone for several months and all can be well. I've long understood that a box of new batteries last longer when placed in the freezer while waiting for use, so all that makes a bit of sense. We never let her sit longer than 45 days before we move again so far. Snow will slow us down a bit, if/when it comes to Virginia. This has been a wonderful "first season" with The Silver Otter, over 20,000 miles; 26 states; 1 province. We'll add three more states in January. Thanks again!
Old 12-29-2011, 10:11 AM   #10
Master of Universe
Gene's Avatar
Greg, dry cells are supposed to last longer if kept cold, though I'm not sure the freezer is the best place. But wet cell batteries can freeze and that's not a good thing as I understand it. That happens when the water gets low in an unsealed battery, but the point of not letting water get low is not to let them freeze.
In thinking about how to get them out, two things with hooks at the end would work too—slide them along the side of the battery and pull. A nail or screw through a stick or piece of metal or anything with a hook. Push some ball bearings under them and they will come out easier.
Gene
Old 12-29-2011, 10:25 AM   #11
ole-red's Avatar
2007 19' International CCD
2002 19' Bambi
2005 30' Classic
Dover , Arkansas
Banjobill
Off subject, but what kind and model of banjo is that you have pictured?
ole-red is offline   Reply With Quote
Old 12-29-2011, 06:15 PM   #12
Ottawa , ON
Gene
Gene, I love those "Wile E Coyote" style solutions!
Old 12-29-2011, 07:41 PM   #13
lewster's Avatar
Per Lifeline factory spec: you can leave a fully charged set of Lifeline batteries for up to 90 days before requiring a 'boost' charge. Just be certain that the batteries are fully isolated from any loads (completely disconnected).
Old 12-30-2011, 10:15 AM   #14
2011 31' Classic
Images: 8
@lewster: Way Cool. THANKS.
battery, battery boxes, battery disconnect
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 02:33 PM
2004 Land Yacht Chassis Battery? RAG Land Yacht/Legacy Motorhomes 11 02-01-2012 07:19 AM
Battery Issues aswbe Batteries, Univolts, Converters & Inverters 29 08-08-2011 07:27 PM
