Old 11-03-2010, 09:15 AM   #29
dznf0g's Avatar
Oswego , Illinois
Originally Posted by RichHog View Post
This should be inserted in every Trailer manual that comes with a trailer with "the Switch".
The PO had replaced only one of the factory batteries a few months back, Should the other battery be replaced as it is the weak link in the overall power in the system?
Batteries should always be replaced in pairs (or entire bank, if more) unless all are just a few months old (ie. you got a defective new battery and it failed early in life).
In practice, I'm not sure what I'd do if my other battery was only a year or so old. I would do some extensive testing out of the coach before assuming the replacement and the "slightly used" one were performing differently.
That being said, I think pretty much all the "experts" will tell you to replace all hooked in parallel (12V) or series (6 V) should be changed out together.
Old 11-03-2010, 11:52 AM   #30
wbrownrr's Avatar
2002 22' International CCD
San Luis Obispo , California
My experience is identical to SilverGate's (see posts #25 and 26). I also have a solar system on my AS.
Wayne
2002 22' CCD
2008 Dodge Ram 1500 5.7L Hemi
wbrownrr is offline   Reply With Quote
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 6 02-08-2013 07:34 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 11:22 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
Auto Battery problems.... kzener40 Airstream Motorhome Forums 10 08-05-2002 07:37 PM
