06-08-2016, 08:35 PM
2016 23' Flying Cloud
Suquamish
Battery Disconnect Switch issues
Our first Airstream! We love our 23FB Flying Cloud! We have used it once, at a full hookup site. I went to check on things in storage before our next upcoming trip and found that the batteries are dead. It’s at a storage facility so we cannot charge in-place. I thought I switched it to “store”, but now I’m not sure. The battery disconnect switch doesn’t stay in the “use” or “store” position, but only toggles back and forth without a click.
Is it supposed to stay in position? Any advice?
06-08-2016, 08:49 PM
2016 22' Sport
2020 25' International
Clinton
, Land of Purple Mtn Majesty,Montana
Mine moves from off to on with a very decisive "click". There is also a plate on the switch mechanism to indicate which is which. Mine is a 2016 Sport 22FB.
06-08-2016, 09:32 PM
Suquamish
Thanks - starting to wonder if it's a defective switch.
06-08-2016, 11:02 PM
2007 23' Safari SE
San Diego
It is probably not defective, but it is a very frequently misunderstood and confusing switch, especially for new owners.
There are many threads about this, such as this one:
Battery Disconnect Switch Not Working (for the short answer)
or Battery Disconnect Switch, Solar, and AGMs (for the long answer)
Welcome to AirForums... the Advanced Search feature is your friend!
06-09-2016, 01:13 AM
2007 22' International CCD
Corona
Interestingly, it's actually a latching relay. It needs battery power to connect and disconnect the battery.
You are sorta stuck wherever it landed until you get your batteries charged somehow and can then operate the relay.
It's an Airstream catch-22 of sorts.
06-09-2016, 12:17 PM
2015 28' Flying Cloud
Glen Burnie
, Maryland
Battery disconnect issues
I had the same problem. There are two fuses on the battery disconnect switch. Both fuses blew out and resulted in inability to toggle the battery on or off. The fuses are standard automotive fuses. Biggest problem was getting to the disconnect switch to replace the fuses.
06-09-2016, 02:29 PM
Corona
Yup. Ours is on the front wall of the AS under the bed. Real hard to reach.
06-10-2016, 11:32 AM
2019 25' Flying Cloud
Sequim
If you left your AS for several weeks the battery will discharge regardless of the switch position due to phanton current draws - LPG detectir is one of thses. Entertainment systems are another possible draw.
See the other threads mentioned above.
06-10-2016, 05:20 PM
Duck Alum(inum)
2008 19' International
Eugene
, Oregon
No-click toggle switch
I have the same issue where the switch clicks when I press it up or down (Use or Store), but then returns to the center position. When I'm plugged into shore power, the light stays on regardless of position clicked. I can think of a better brand name name than "Intellitec."
06-11-2016, 12:16 AM
Corona
Keep in mind the light simply means is 12 volt power on the appliances in the AS.
Because of the way the latching relay works in the AS, there is no way to be sure if the relay is open or shut if shore power is connected.
It's actually working correctly.
06-13-2016, 04:28 PM
Tavares
Is it possible for this switch (if defective) to prevent charging when on shore power?
Last couple days, my coach ('16 27' FC FB) is not charging when on shore power. It DOES charge when connected to the truck umbilical.
Rich
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
06-13-2016, 10:18 PM
Suquamish
We have a portable charger that we use for our boat batteries, and used it to charge the batteries up directly without going through the trailer. We got it up to 11.5, and will hit it up with a cord before our trip. I'm worried that we may have damaged our batteries by letting them go completely dead... time will tell!
06-14-2016, 04:55 PM
2007 23' Safari SE
Reno
, Nevada
We have the same issue on a 25 2016
Also was told to click switch up whenever charging source is changed
Further while generator or ground power all systems work like it is directly converting to the coach but not charging the batteries
Vey annoying when your jack won't power up unless generator attached. :-(
Ideas
Charger /. Switch. /. Batteries were repalce 4 months ago
06-14-2016, 05:45 PM
2005 30' Classic
Burlington
, Ontario
I never could understand what that switch was doing in our trailer, so I don't bother with it!
When we are home and take the trailer to the storage yard, I remove the batteries and bring them home. They are AGM's and self discharge very slowly, but even so, I put a charger on them in our garage every time before I take them back to the trailer for a trip.
When we are camping with the trailer and will be at a site with shore power for more than just a couple of days, I like to disconnect the batteries because we still have the original
non-smart charger in the trailer and I am concerned that leaving it connected for a long time could damage the batteries. (Im not really sure about that.)
I have replaced the original battery clamps with the type that have a quick disconnect knob so as to make it easy to disconnect them from the charging circuit.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
06-15-2016, 09:20 AM
2007 23' Safari SE
San Diego
Rich
Batteries not charging when on shore power sounds like a converter problem.
04-25-2017, 10:28 PM
2008 23' Safari SE
San Luis Obispo
Where are the fuses located? My battery disconnect switch is not working either.
04-26-2017, 07:36 AM
1967 17' Caravel
Austin
The fuses are located on the latching relay which will probably be located near the battery. The way mine works is light always on regardless of relay position when connected to shore power. However the switch/relay still works to disconnect/reconnect the battery. So, when on shore power and my battery meter says 100% charged, I tend to disconnect the battery (light stays on). This is probably not necessary as I have new 4-stage converter/charger.
When on battery power alone, the light turns off when battery is disconnected...indicating no 12 volt power source.
04-26-2017, 09:15 AM
2016 19' Flying Cloud
Austin
The best way to tell if it's in use or in store is to disconnect from shore power. If the light goes out on the switch you are either in store mode or your batteries are dead. Try switching to use if needed to see if it works on 12v from the battery. For whatever reason the switch is not a rocker switch, in that it always returns to the middle position.
Also, if you can't get your tongue jack to work because your batteries may be discharged, try hooking up your vehicles 7-way plug and operating the jack from your TV power... worked for me.
04-26-2017, 10:48 AM
1967 17' Caravel
Austin
The rocker switch returns to the middle position because it is a momentary switch. If it stayed to one side or the other, the switch would continuously supply voltage to the solenoid coil which in turn would quickly drain down the battery and/or burn out the solenoid coil if not rated for continuous duty.
04-26-2017, 10:58 AM
Austin
Right, it's a relay switch I think. Someone in an earlier post was thinking it wasn't working because the switch returned to the middle position. I was trying to answer several post... I should have quoted them.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Toronto_Guy |
Batteries, Univolts, Converters & Inverters |
10 |
06-26-2020 02:35 PM |
Battery Disconnect Switch, Solar & AGMs
SilverGate |
32 |
08-26-2019 01:23 PM |
To disconnect or not to disconnect
urnmor |
Towing, Tow Vehicles & Hitches |
36 |
02-22-2017 10:24 AM |
Battery Disconnect Switch Question
MaryD |
4 |
07-13-2013 08:19 AM |
nsbcpa |
5 |
08-10-2012 05:11 PM |
