Old 05-09-2012, 03:35 PM   #1
2006 19' Safari
New Smyrna Beach , Florida
Battery Disconnect Switch
Just returned from a weeklong trip. Now the Battery Disconnect Switch will not come on unless connected to shore power.
Any thoughts? Bad Switch?
nsbcpa is offline   Reply With Quote
Old 05-09-2012, 04:37 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
not sure I understand. the lights, etc. work on 12 volts when connected. but do not work when not connected? On my 88 model the battery switch cuts the 12 volt system off whether it is plugged in to shore power or on battery.
Are your batteries dead?
Old 05-09-2012, 06:16 PM   #3
2006 19' Safari
Batteries are fine..........
Old 05-09-2012, 07:36 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
The "use/store" switch light should be red (on) in either position when you are plugged into shore power. It should only go out when you are on battery power only and you switch it to "store"...at that point none of your 12v lights or systems will not work... If you are on battery power, and the over head lights and other 12v systems work, you are not disconnected from the battery...so I'd investigate the switch itself...
TB & Greg and Abbey Schnauzer
#3954
Old 05-11-2012, 04:52 AM   #5
2006 19' Safari
Thanks, a new switch is on order.
Old 08-10-2012, 05:11 PM   #6
2007 27' Classic FB
Ridgefield , Washington
Was the switch the problem?
John & Lisa
Woosch is offline   Reply With Quote
