Old 10-11-2016, 11:57 AM   #1
dasams's Avatar
Marin , California
Battery Disconnect Switch
I have a 2017 FC 25 and am wondering about the light on the battery disconnect switch.
I can hit the switch up for Use or down for Store and the switch will return to the center neutral position so you can't tell at a glance which mode is active. Is this normal?
My question is that our monitoring light is always red and doesn't flash, turn on or off when I cycle the switch. Is this normal?
Also, I can hear the solenoid click in the Parallax each time I operate the switch. Normal?
As usual, when I have a question and consult the owner's manual, there's no mention of my issue
Thanks, Dave
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Old 10-11-2016, 12:25 PM   #2
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Hi Dave. It is normal for the light to be on in both positions if you are connected to shore power, and hearing the solenoid is not unusual. Best, Joe
jayseejay is online now   Reply With Quote
Old 10-12-2016, 09:51 AM   #3
DAO
2017 25' Flying Cloud
Angleton , Texas
I have a 2017 FC 25 as well. The battery disconnect lights up red when there is power (from any source) on the "system" side of the disconnect device. With no shore power to your unit, it will operate as you would expect; namely it is red when disconnected and not red when connected. The confusion comes in when you have shore power connected. It will always be red regardless of which mode it's really in. It should also be noted that this disconnect only disconnects the Power Center from the battery. Other battery loads (jack, solar panel outlet, inverter, etc) are still connected. Here is a link to the BD0 disconnect used in the unit: http://www.rvtechlibrary.com/electri...disconnect.pdf
doutterson is offline   Reply With Quote
Old 10-13-2016, 08:19 AM   #4
dasams's Avatar
Marin , California
Originally Posted by doutterson View Post
The battery disconnect lights up red when there is power (from any source) on the "system" side of the disconnect device. With no shore power to your unit, it will operate as you would expect; namely it is red when disconnected and not red when connected. [/url]
Good info and thanks for the link. Dave
2018 FC 27 FB
2017 FC 25 RB Gone
Battery Disconnect Switch Issue ATE123 Sprinter and B-van Forum 17 08-28-2017 07:31 AM
Battery Disconnect Switch Not Working Toronto_Guy Batteries, Univolts, Converters & Inverters 9 04-13-2015 05:39 PM
Battery Disconnect Switch Question MaryD Batteries, Univolts, Converters & Inverters 4 07-13-2013 08:19 AM
Battery Disconnect Switch nsbcpa Batteries, Univolts, Converters & Inverters 5 08-10-2012 05:11 PM
Battery Disconnect Switch, Solar & AGMs SilverGate Batteries, Univolts, Converters & Inverters 29 11-03-2010 10:52 AM
